20v BT 7age is build underway
Re: 20v BT 7age is build underway
Which Stock ECU? Blacktop or 7AFE?
Blacktop sir...
im not sure who is asking what to who?....?
I know v33sonota already has a rod solution but for you other guys doing 7As I only need about 7 more people to commit before I can do a run of Brian Crower 7A rods.
Sorry v33sonata i did not mean to jump in on ypur thread or any.. If any you would more about a 7ag then i ever could learn about it..
To those who wonder about the blacktop ecu on the 7ag bt ...im not sure if it would work... I just happen to have something which look like a 20v bt 7ag sitting in my garage so im thinking about testing it to see if it really work... That all..
LOL no worries! and I was told that the BT ECU would work just fine on a 7a bt conversion but it wouldn't be the best fit.
Sorry for the delay! It's been a long awaited but she is ready for install. Hopefully I can find time before Christmas! For now enjoy the pictures.
Specs:
Stock Cams (for now)
83mm bore
JE 11.1:1 C/R Pistons
Eagle H-beam rods
Cometic 83mm Head Gasket
ARP Head Studs
ALC Bearings
techno toy tuning ITB's
Manon Timing belt pulley kit from http://www.battlegarage-rs.com/
Special thanks goes out To Grant @ battlegrage and Barry @ Manon Racing Products
Specs:
83mm bore
Eagle H-beam rods
ARP Head Studs
ALC Bearings
looking good.. let us know how you like it..
any rear of engine shot? what water kit are you using?
phanist wrote:looking good.. let us know how you like it..
No its attached to the stand. I can take one when I put the clutch on before I install it in the car. What do you mean buy what kit are you using?
Wow that's a nice piece of an engine!!
But why did you use 83mm pistons right away? You would have no room in the future (or when something goes wrong with your build) to put even more oversized pistons in i think.
I'm really curious how it'll run with the blacktop ecu. I'm thinking of making a 7AGE 20V in the future as well with only an uprated block, but with a stock head.
I have used this block for 2 other projects so I had to go 83mm as last time I went 82mm. But I did have it sonic checked and they said 83 is no problem. I might even to able to do 84mm.
danggggg are you running it with out the cooling system>? stock BT ecu?
congratz BTW
congratz BTW
LOL yea.... isnt it air cooled?
NO it was 1st start up making sure all worked before I added the other stuff.
Looks nice and runs well! You shouldn't only put as breather filter on the cam cover breather pipe, cause I think that's whistling
I just ordered a red one
and a set of ITB filters.
what did you do to make that stock 20v header work>? with the rest of the exhaust system>? an adaptor>?
Just bolted it in. I havn't had any issues.
any dyno results yet?
my diary/build: http://club4ag.com/forums/viewtopic.php?f=7&t=10479
