Blacktop 20V auto ecu on manual gearbox?
onnaj
Postby onnaj » Thu Feb 14, 2013 11:58 am
Hello,
I can buy a 4AGE 20V Blacktop engine and a complete wiring harness with auto ecu. Can i run the auto ecu without problems on my C52 manual gearbox or would thise give problems. Would i also loose power by using this ECU?
Thanks!
Check my 4AGE 20V BT teardown, rebuild and transplantation over here --> http://club4ag.com/forums/viewtopic.php?f=7&t=3382
Dr Tweak
Re: Blacktop 20V auto ecu on manual gearbox?
Postby Dr Tweak » Fri Feb 15, 2013 1:06 pm
No problem, people run auto ECUs all the time! Just need to have the wiring taken care of, you can convert your existing harness or use one of these: http://www.tweakdperformance.com/online ... ducts_id=1
onnaj
Postby onnaj » Sat Feb 16, 2013 6:52 am
I've already been able to buy the 6 speed manual ecu and wiring from Reedjayson-ae86. So no hassle for me anymore. Hopefully i get the engine and wiring the coming weeks so i can prepare the engine and wiring and then enjoy :D
