Track Setup!!
Be nice to others.
azndrifter50
Track Setup!!
Postby azndrifter50 » Mon Aug 18, 2014 10:13 am
Does anybody track their 86? And what do you guys use and set up for suspension and offsets?. Wheels tires and gear ratios?
I like streetable and mild track set up.
Im just using 15x7 0 offset. Pressure -10 depends how how on tires. Camber front Neg 2 and 0 rear. Im gonna play with more setup as im replacing more stuff slowly. And anybody using hts shorts vs coilover i get mixed reviews.
Thanks guys for sharing!!
Thanks,
Brian
Ae86 Ultimate
Master Mechanic and Master of the Custodial Arts
Los Angeles, CA
chohdog
Re: Track Setup!!
Postby chohdog » Wed Aug 20, 2014 5:02 pm
How do you get -10 psi for tire pressure?
Setup depends on what tires you're using, what motor sport you're participating in, and what you have that is actually adjustable.
ToeKnee805
Re: Track Setup!!
Postby ToeKnee805 » Wed Aug 20, 2014 11:45 pm
I drift my car at Willow.
Suspension mods:
Megan Coilovers
AW11 Manual Rack
NST Steering Spacer
T3 Knuckles w/ TieRods
T3 NCRCA
Steel Braided Brake Lines
Whiteline Panhard Bar
TRD 2Way Diff
Alignment:
0 Toe
-3.5 Camber
+2.75 Caster
Wheel n TIre:
Varrstoen V3 15x8 0 offset, 15x9 -5 Offset
Toyo R1R 195/50/15, 205/50/15
Engine:
Built Bluetop 3rib with TRD header and 5Zigen Exhaust
azndrifter50
Re: Track Setup!!
Postby azndrifter50 » Thu Aug 21, 2014 1:01 pm
I meant tire pressure when u run psi max minus 10 psi and do ppl run on that track with just 15x7 205/50/15? Or 195s?. i think i ran on 38psi the last time?! Its been awhile. Last tires i ran were azenis 615? I sold everything back on stock suspension now but looking for trackable set ups. Just getti g ideas.
Front on t3 ncra camber plates neg 2 camber zero toe. Rears are always zero since i dont have adjustable 4 links and solid diff.
Thanks for the inputs guys
Thanks,
Brian
Ae86 Ultimate
Los Angeles, CA
Return to “Fun Talk”
