20 Valves of Goodness.
Zanek
Postby Zanek » Tue May 20, 2014 8:14 am
Okay so I've been using this site for awhile now for information and what not, I thought it's about time I make a build thread.
I've owned a couple of corollas with 16v's in them, this is my current ke70 corolla, I bought the car with a 16v in it but after countless issues I decided to finally go with a 20v. I've always wanted to pour a load of money into a High Comp 20v build and I have finally pulled my finger out and am getting it sorted.
So this is my build so far and whats to come.
4A-GE High Comp 20v Blacktop
CP 81.50mm bore high compression forged pistions C/R 12:5:1
Brian Crower H beam forged conrods
ARP head studs
Fidanza Adjustable Cam Gears
HKS timing belt
Kelford 194-C racing cams
Intake: 284' Duration 9.30mm Lift.
Exhaust: 278' Duration. 8.50mm Lift
Kelford Cams racing valve springs
Fully Reconditioned Block and Head
Port and Polish
New Water Pump
New Oil Pump. Ported and High Pressure Kit.
TRD 0.8mm multi layer metal head gasket
1zze Coilpacks
All SamQ Engineering RWD Conversion Parts.
Koyo 53mm core Aluminium Radiator
Custom Full 2.5' Stainless Steel exhaust system tucked up over the diff with High flow muffler and resonator.
Engine Management:
Haltech Platinum Sport 1000
Brakes:
Ae86 JDM Brake callipers
Goodridge braided brake lines.
Ae86 Slotted and vented Rotors.
Suspension:
30mm RCA's
New AJPS Tie Rods
Adjustable toe arms
New Bc Gold Hight and Damper Adjustable 8k Front Coilovers
New G4 8k Hight and Damper Adjustable Rear Coilovers
AE86 JDM Steering Rack
AE86 JDM Steering Arms
Lengthened and Boxed Xt130 Lca's (20mm)
I also have a wheel hoarding problem.
Hoshino G4 14x8 -7
SSR MK3's 14x8.5 -8
Equip 01's 14x8 -15
SSR Mk2 14x7
SSR Longchamps 14x6.5 +12
Rear Arches are front ke70 guards welded on the rear.
All rust just out and Fresh respray.
Nardi Steering wheel.
Velo Gp90 Fixed Back Bucket Seat.
Some of the goodies on the way.
T-series Diff with 4.77 Cw/p and Locker/lsd.
Either PowerCraft, Jasma or Custom 4-2-1 Headers Still unsure on which one to go with.
Defi Oil pressure, oil temp and water temp Gauges.
Another Gp90 and Harnesses
Just some photos of the car from when I got it to now. (I like taking lots of photos)
When I bought the engine.
And Finally where I'm at now. Painting Engine Bay and getting ready for motor to go in when It gets back.
Re: 20 Valves of Goodness.
Postby oldeskewltoy » Tue May 20, 2014 8:49 am
I'd love to see some views of the head before it gets re-assembled.... :D
kaosboss
Postby kaosboss » Tue May 20, 2014 7:31 pm
Nice ride......keep the goodness coming
rekik
Postby rekik » Wed May 21, 2014 7:33 am
EXCELLENT! can you post a pic of the engine in the car...
Bk65
Postby Bk65 » Wed Jun 18, 2014 8:35 am
I need to get my wheel collection up.
Zanek
Postby Zanek » Thu Jun 19, 2014 12:25 am
Visited my engine builder today, arrived to see this, new pistons/rods and head is all ported and cleaned, decided to go oversized vales and Toda oil pump gears, will have redline somewhere around the 9000-9500 range. Block is being honed at the moment and all should be going back together in the net few weeks, just waiting on head studs and adjustable pulleys.
Also got bored and decided to polish the wiper motor and heat tap and clean up the booster. Pretty stocked with how things are coming along.
kaosboss
Postby kaosboss » Sat Jun 21, 2014 5:59 am
Joemidlothian
Postby Joemidlothian » Sat Jun 21, 2014 12:26 pm
Very nicely done. Going to be awesome to see how this all works out in the end!
Musician- Avid Car enthusiast- Eventual Trueno Owner <3
(Fingers Crossed)
Zanek
Postby Zanek » Tue Sep 23, 2014 6:14 am
So I’ve basically come to a stand still until I get my motor back which shouldn’t be to far away, then just need to find someone to tune/wire it up.
Messed around with my dash which I’m pretty happy with and slowly putting the car back together getting most things painted/cleaned before going back in.
IndiaDorifto7
Postby IndiaDorifto7 » Tue Sep 23, 2014 4:31 pm
I'd like to see a boso/kaido style racer, it'll probably require some fab work tho.
KP61!
Postby KP61! » Tue Oct 21, 2014 11:16 am
Very Nice build man. I love the Hoshinos. Perfect size
RuizXIII
Postby RuizXIII » Fri Oct 24, 2014 7:41 pm
Man, this looks great. Keep it up! 20V and KE...a beauty of a mix
irony.cc
shagymc
Postby shagymc » Fri Oct 24, 2014 10:18 pm
What made you go with that particular EMS? I want to go that route with my 20v and add COPs but the quote I just got from a local shop was 3700 dollars which is more than i paid for the whole damn motor. I'm trying to do research on it so that i may take the install myself and just pay for tuning. Build looks great!
Zanek
Postby Zanek » Fri Oct 24, 2014 10:48 pm
Little bit of an update, got my engine back the other week so decided to clean up my gearbox.
Before.
Gearbox, meet acid..
Came up awesome! Also got a new 5 Puk Sprung Exedy Cluch, ARP Flyweel bolts etc etc...
Got the motor all ready and in it went. Just taking my time polishing/painting everything before it goes in.
I'm in no rush to get it finished but kinda aims for March 2015.
grappletech
Postby grappletech » Sun Oct 26, 2014 4:32 pm
Question, what the heck is that acid????
87 SR5 Coupe Shell. (Sold)
86 SR5 Hatch Shell
86 GT-SR5 Coupe 20v Swap
shagymc
Postby shagymc » Sun Oct 26, 2014 9:03 pm
That tranny looks brand new! Holy ****!
RuizXIII
Postby RuizXIII » Wed Oct 29, 2014 1:24 pm
It looks like the 'mission is melting away in that pic with the acid. Neato, ha.
irony.cc
Zanek
Postby Zanek » Sat Nov 22, 2014 4:41 am
New Fenix Rad in and fitted ITB’s.
RuizXIII
Postby RuizXIII » Wed Nov 26, 2014 9:04 am
Engine is looking great, man.
What was the acid you used to clean the gear box?
irony.cc
InitialB
Postby InitialB » Wed Nov 26, 2014 10:47 am
I also want to know what that acid was. NEED DAT.
Zanek
Postby Zanek » Thu Nov 27, 2014 7:39 pm
Not 100% sure on what acid it was, pretty sure it was just typical Hydrochloric Acid.
New cam cover. 2 Speed flow fittings for catch can and custom internal baffle.
Jeonsah
Postby Jeonsah » Sun Dec 07, 2014 1:44 pm
Dope Build. Keep it up. Really like how clean this car is coming out. Great work man :D
Zanek
Postby Zanek » Tue Dec 09, 2014 10:52 pm
Yeah trying to keep it as clean as possible, thanks dude
Zanek
Postby Zanek » Wed Aug 19, 2015 4:00 am
Washed it for the first time in like a year and a half.
Postby oldeskewltoy » Wed Aug 19, 2015 10:10 am
those headers don't look like they have been heated yet.... assume the start up has been delayed??
Zanek
Postby Zanek » Wed Aug 19, 2015 11:18 pm
oldeskewltoy wrote:those headers don't look like they have been heated yet.... assume the start up has been delayed??
Yeah still hasn't been started yet, been sorting out some personal stuff, getting a new tilt trailer made in the next 2 weeks then off for some fab work, bash plate, catch can etc etc. then off for tune wire up after that.
