Jimmee1990 wrote:The rings and pistons reach the exact same place on every single revolution of the engine no matter what revs(discounting the tiny amount of side clearance they should have in the ring grooves), it's not like revving it harder changes the stroke length or the rod length does it. Don't get started about alloy rods and big revs and rods stretching, this is a standardish 4age we're talking about.
Funny because I have talked to Loyning, Hasselgren and other engine builders about squish area and rod stretch and they all have said roughly the same thing.
None of them recommend tighter than about .8mm squish area to factor for rod stretch to make sure the piston won't hit the head. A couple suggested that the stock rods will probably stretch about as much at stock redline as high end rods will on a high spinning motor.
