Crono's F20 Swap!
Crono's F20 Swap!
*cough*
Re: Bought this recently
Rays - Project Mu - TE37 club
BLUE MOON / CUSCO
AE86fightclub.com
PM me for Contact
BLUE MOON / CUSCO
AE86fightclub.com
PM me for Contact
Last edited by kendallspower on Sun Jan 05, 2014 12:47 pm, edited 2 times in total.
The Feels of hitting dat V-Tec Bro
Dude, they sent you the wrong motor! I hope you get your money back!
Still looking for wiring harness and a supra rear end.
- Mr.Fujiwara
nice i saw your car in person Efrin is working on it right?
from suspicious garage? i went with a buddy to buy a
s13 dash from him cool guy
Old username: Charskiezz
20V BT: Traded For F20c Swap
Mr.Fujiwara wrote:nice i saw your car in person Efrin is working on it right?
Yup.
Just secured myself a supra rear axle. Very excited.
cool. look forward to seeing more
So I'm contemplating either cutting off the SR5 mounts and welding it onto the supra, or getting some custom 4-links made.
Thoughts?
Thoughts?
T3 has a 5 link that supposedly makes it a direct swap. Look under their ae86 suspension section. BUT, I'm not sure if the spring and shock mount locations differ between them. IF they do it might be an issue.
If it was me I'd cut/weld on ALL the ae86 pickups, but only because I'm picky (I'm also not big on heim joints). Did he quote you on the labor cost for that? I can't imagine it's cheap.
Making your own links would be the least expensive, but that's probably only the case if you piece everything together yourself. (Again, still not sure about the springs/shock mounts.)
https://technotoytuning.com/toyota/ae86 ... r-end-swap
I saw the T3 setup. But since my 86 is going to be a daily driver, I'm not sure if I want my spine shattered every bump I go through
Anyone have experience with the ride quality?
I noticed a little more gear noise after installing the t3 panhard, but didn't detect any added vibrations/harness compared to prothane poly bushings. I have no experience yet using heims on the 4 links but I imagine it's loud and harsh
Noise and vibrations will be pretty noticeable. Harsh though ... not directly from the 4 links, it depends on the springs and shocks you are running with. Rubber and Urethane bushings are for all intent and purpose springs, urethane just has a higher spring rate. They absorb deflection. Since the live axle is un-sprung all of the deflection will be forced through your springs since it will not have any where else to go with the spherical bushings (heim joints etc). If you have soft springs you will have a lot more wheel hop than before though, and the rear end will be jumpy / a little scary.
Don't want any of that. I am a decent driver, but don't want to be dealing with that all the time.
I guess cutting and welding is the way to go. Thanks guys! Stay tuned for more updates.
John H. wrote:
Success. That is all.
I like where this is going
Perhaps I'm confused,
what was the point of me getting meme'd?
He's referring to the first couple posts lol...
*shrug*
Reliable power. Can't ask for more than that.
That looks like a win to me.
Ahoy there! Pictures galore!
All work done by Suspicious Garage:
https://www.facebook.com/pages/Suspicio ... 9643564146
SR5 rear end with furniture cut off:
Supra rear end with furniture attached:
I wonder what goes here?
Supra rear end installed:
Picked this up:
Another engine bay shot:
Shiny!
New gas tank:
Also got the following items from Vern:
Picked this up:
Shiny!
New gas tank:
Could I have this moved to Member's Build Up Logs?
Re: Crono's F20 Swap!
Can't forget these!
are you worried about the F20c causing a change in the suspension geometry / handling?
UCSB Alum
clean
