a few engine bits and bobs
dai-ric-jay
Postby dai-ric-jay » Fri Mar 28, 2014 6:33 pm
Parts are located in London England,
most bits are from a 4AGE engine blue top big port
Please email me for any enquires: dairicjay@live.co.uk
- bottom end block (needs reconditioned) was £50 [COLOR="#FF0000"]now £30 to shift[/COLOR]
- brand new distributor cap £5
- VHT painted red dizzy heat shield £10
- crank shaft (needs balancing) £swapped
- set of cams shafts was £20 now £10
- set of cam gears was £20 now £10
- cam gears back plate powder coated yellow was £20 now £10
- cam gears/belt cover set was £30 now £20
- oil pump £5
- oil filter bracket £5
- alternator was £20 now £10
- alternator pulley £5
- water pump housing £10
- rwd standard radiator hoes 2 piece set £15
- corolla gti t-vis intake manifold was £30 now £20
- intake manifold butterfly £10
- injectors rail £10
- set of 4 pistons £20 the lot
- coil complete with ignition £35
- radiator water bottle £10
- VHT painted red starter motor heat shield £15
- 4AGE rwd ecu £40
- fuse box cover £5
- Greddy GRACER Airinx-I Air Filter RS type 3"id in good, used condition £20
- pair of rocker covers repainted 1.) 2 coats of VHT primer 2.) 2 coats of very high temp paint in red 3.) 3 coats of VHT clear coat £60
- stainless steel spark plug cover £10
- pair of rocker covers repainted 1.) 3 coats of VHT primer 2.) 3 coats of very high temp paint in red 3.) 3 coats of VHT clear coat
+ stainless steel spark plug cover
+ A2 stainless steel bolts for spark plug cover
+ spark plug cover gasket
+ toyota oil cap
£80 the lot (picture coming soon)
all engine bits price drop or offers
Chris_nuisance
Re: a few engine bits and bobs
Postby Chris_nuisance » Thu Apr 03, 2014 11:52 am
how much would you let all of the engine parts go for if buy:
- oil pump £5
please send me an email
Lunadamulligan@yahoo.com
