4ac - 20v silvertop swap trueno
Stevie-D
Postby Stevie-D » Sun Jan 05, 2014 11:17 pm
Hello everyone I'd like to say that I am new to this site ,and to the world of cars. Right now I have the ultimate goal of putting in a 4age 20v silvertop into my trueno. The only problem is I don't know a lot about cars. I have never done an engine swap before, but it is something that I wish to pursue. After hearing what they sound like with itbs I knew that's what needs to be in the dream car.
Stevie-D
Postby Stevie-D » Sun Jan 05, 2014 11:32 pm
So far i the cheapest engine I've found is $590. But I'm a little overwhelmed I see on here a big list of things that I'm going to need. Where is the best place to begin after I have found an engine? Is my first question. I'd like to have this thing running in the next 6 months.
Stevie-D
Postby Stevie-D » Sun Jan 05, 2014 11:36 pm
Can I hook up a 20v silvertop to a t50 transmission? And if that is possible is what i need a new flywheel and/or clutch?
morgan
Re: 4ac - 20v silvertop swap trueno
Postby morgan » Mon Jan 06, 2014 9:25 am
look in the DIY section, I did a write-up there. research is key. this swap has been done many times, and theres info everywhere, just search
Stevie-D
Postby Stevie-D » Mon Jan 06, 2014 11:47 am
ooh i think yours is pry the best one ive found so far. well step one buy the motor here i go !
morgan
Postby morgan » Mon Jan 06, 2014 1:01 pm
well be warned, the 20v swap isn't the easiest. theres a lot to do, and you did mention that...
Stevie-D wrote:The only problem is I don't know a lot about cars. I have never done an engine swap before, but it is something that I wish to pursue.
...but if you have the determination and tools, its possible.
Stevie-D
Postby Stevie-D » Mon Jan 06, 2014 1:03 pm
yes i have been looking at a lot of things but I am determined. But i still cant find that answer to my question about the t50 hooking up to the 20v.
morgan
Postby morgan » Mon Jan 06, 2014 2:47 pm
Bolts right up. Sr5 bellhousing keeps the clutch slave on left side which is the side of the 4ag exhause. Need a heat shield or better to get a gts bellhousing and have it on the right side out of harm and heats way. 4a is the block code so whether its a 4ag, 16v 4ag, 4agze, etc...the bellhousing bolts to the block. There are T50's from iirc 2tc and/or 3tc motors. I dont think that will bolt up
yoshimitsuspeed
Postby yoshimitsuspeed » Mon Jan 06, 2014 4:34 pm
You will just have to make sure to match flywheel and clutch kit. The 20v is 212mm the T50 is 200mm.
If you run the 212 kit you will need to get the T50 throwout bearing and pilot bearing seperate.
I have those on my website but I am also trying to get Exedy to make me a 212mm kit that includes the T50 bearings.
http://matrixgarage.com/store/ae86-clut ... drivetrain
Quite honestly unless you are planning on running boost or a crazy high RPM build I would just go with the 200mm combo for simplicities sake.
morgan
Postby morgan » Mon Jan 06, 2014 4:36 pm
212mm fits in the T50
