$120 OBO
4AGE Rods. 42mm/20mm ends - $OLD
SC14 Supercharger off a previa- $OLD
phanist wrote:is this 7rib block the same as the 20v BT block?
ga_goosh wrote:Chubi,
what condition is the crank? was there any spun bearings? and will you sell just the crank?phanist wrote:is this 7rib block the same as the 20v BT block?
this block is a 16v block the 20v blocks have the cut out like the 4af blocks but you can build a 20v with this block. you will just need a 16v pan.
Chubi wrote:bumppp
sgonzalez wrote:Chubi wrote:bumppp
Hello Pal Interested on the Rods I sent you an IM
