![Image](http://nonstoptuning.com/images/Cars%20Drivers/NST%20AE86%20WILL/NSTAE86-WP-0007.jpg)
http://vimeo.com/41261151
ORDER ONLINE, SHIPS TO YOUR DOOR: http://nonstoptuning.com/BC/pBCcoilovers.html
Coilovers that strike the best balance between performance and cost. We have designed all the most popular and essential features into our coilovers while keeping the end price down for the consumer. Whether you are cruising down the street, enjoying your favorite twisty mountain road or tearing up a race track, we have a coilover system for you. You get to choose your spring rates; either keeping the recommended spring rates or selecting from our available stock. We even install the springs for you so you don't have the hassle of doing it in your garage or living room. As an added service, if you choose spring rates 4k higher or lower than the recommended setting we will revalve the dampers for you. We beleive you shouldn't have to pay a premium price for a quality coilover system.
FOR THE AE86 COROLLA:
Front + Rear Full Set With Spindles
Front Only With Spindles
Rear Only
Also available for other makes and models.
Mono Tube shock design
30 Way adjustable
Adjustable camber plates
Separate full length height adjustable
One year warranty
Rebuild services available in the U.S.A.
Custom spring rates and valving available
BC RACING SUSPENSION NOW AVAILABLE WITH SWIFT SPRINGS AS SPECIAL ORDER ITEMS!
** Swift Spring Technical Advantages
-Swift proprietary material along with advanced cold winding process allows Swift springs to be manufactured using a thinner wire diameter with fewer coils making the springs the lightest magnetic metal springs available on the market.
** Swift Accuracy
-Swift Metric Coilover springs feature the highest linearity of any spring out there. Along with the widest stroke range possible, the springs stay linear throughout MORE of the usable stroke range compared to anything else out there. Swift guarantees the spring rate accuracy to be +/- 2% within the advertised spring rate!
** Industry leading spring response
Swifts superior spring compression speed responds much quicker over undulating road surfaces so the tires have a lesser tendency to skip. This enables the tire to stay in contact with the road, improving traction and helps keep tire temperatures down.
Please contact NonStopTuning for availability and special pricing.
NST - NonStopTuning
www.NonStopTuning.com
