Transmission Front seal and gasket?
rumsawatti
Wasnt sure if to post here or in WTB but where can I buy the transmission front seal and gasket? The only place I found selling it was Cabe toyota and im hoping I can maybe get it locally from autozone or something. Does anyone have a part number for a generic one or it can only be bought from toyota? Thanks.
Re: Transmission Front seal and gasket?
I don't think that there is any seal that isn't available aftermarket, the gasket may be in an aftermarket trans. set but individuals have to come from the dealer.
Call your local dealer, the front oil seal fits a lot of other trans if I remember right, and the big gasket should be available, too. If no bellhousing gasket can be found, hammer down with some RTV. Also, install the input shaft seal into the shaft cover housing with the open end facing the transmission. It looks backwards, but the oil is behind the seal so the front needs to face towards the shaft cover. My trans had a new clutch and seal installed 15 years ago (sat for 11) and the seal was facing the wrong way, so naturally it was leaking, and it even fell out when I pulled the shaft cover off.
Knockoff Crew member #0001
