I WANT TO SALE AS A WHOLE And DELIVERY DEPENDING ON DISTANCE, ALL SALE ARE FINAL.
Located in Duluth ,GA 30096.
Asking price: $1,555 OBO
Includes:
Engine: Recommend machine shop rebuild ($400)
4agze engine,7 Rib Block,Oil filter Adapter, Rods,Pistons(two need to be replaced) Crank Shaft, Big Port Head(Still assembled w/ valve covers and timing gears and new belt& Thermostat housing and sensors, Toyota Oil Cap.)
CT26 Turbo ($100) (Turbo has a little play in the shaft roughly 30,000 miles, hense low price)
Stock Fuel Rail ($50)
4 x Toyota 440cc injectors (cleaned by witch hunter performance) ($150)
Mega Squirt: (Custom built plug and play harness
PNP wiring harnesses, USB adapter and MS tuning cable, MS1 V2.2, TVIS control)
($150)
Stock Engine Harness ($100)
Stock Ecu (If Needed) ($75)
Distributor & Wires ($50)
Exhaust Manifold ($75)
EGR block off plate ($10)
EGR and Vacuum lines ($30)
T-clamps ($25)
Silicon Couplers ($25)
Upper portion of the down pipe ($30)
Big port Intake Manifold ($50)
Stock Throttle Body ($30)
Stock AFM ($25)
Charge pipes ($30)
Blue JDM SPORT Cone Filter ($20)
HKS SQV BOV ($100)
Oil feed line & Adapter ($20)
Air 2 Water Intercooler ($100)
Intercooler pump ($30)
Intercooler reservoir ($75)
Uploaded with ImageShack.us
