diy radiator overflow tank
ajadorifter
Postby ajadorifter » Sun Apr 14, 2013 9:52 am
Cheap Alternative For Your Engine Bay. Also It Will Dress It Up A Lot!
Everyone Probably Has An Aluminum Water Bottle Laying Around. If Not They Are Cheap.
For The Brackets, Welded Two L Brackets OntoImage Hose Clamps. This Provides Easy Removal.
KonaTrueno723
Re: diy radiator overflow tank
Postby KonaTrueno723 » Wed Apr 17, 2013 11:15 pm
Nice diy overflow tank! Accents the engine bay very well..also that intercooler pipe,,man I see all the angles & weld work on it,,awesome! :D
87 GTS Coupe
72 Blown 6-71 Pro Street Vega
RuizXIII
Postby RuizXIII » Thu Apr 25, 2013 10:06 pm
This is pretty crafty haha
It also help if you are handy with the TIG too =)
irony.cc
Jeonsah
Postby Jeonsah » Tue Apr 30, 2013 12:31 am
Badass write up. Ive been trying to figure out where I could get a tank like that! Uahaha great stuff right here!
Cavi Mike
Postby Cavi Mike » Thu May 16, 2013 11:03 pm
That's not aluminum, that's stainless steel. You'd know that if you were the one that actually made it.
pearls ain't free
Postby yoshimitsuspeed » Fri May 17, 2013 12:32 pm
Cavi Mike wrote:That's not aluminum, that's stainless steel. You'd know that if you were the one that actually made it.
Hahahaha
I'm trying to figure out why they cut the lid off. Personally I like to be able to check and fill my overflow bottle.
If you have those skills you can just use cheap stock too. Mine are made out of 4" aluminum IC piping with a weld bung cap and AN bungs for lines.
By the way if anyone needs them I can make overflow bottles to any dimension, spec and volume. I can do it out of stainless but it would be very expensive to do it right. The guy in the pics above did not do it right and his welds will be rusting in no time.
Aluminum however is quite easy.
KonaTrueno723
Postby KonaTrueno723 » Thu Jun 20, 2013 1:11 pm
^^Nice!
87 GTS Coupe
