I'm looking for the parts numbers for the V-belts of a BT. Can't find them on Toyodiy.com.
Anyone who has the numbers and maybe someone has new belts lying around doing nothing?
choi0706 wrote:convert to 16v stuff..
onnaj wrote:I did extra searching and i did find the numbers!
I can get them from Mitsuboshi, yes that are the one Toyota uses also, for about 40 dollar or so. The OEM Toyota ones go for about 100 dollar. I go for 'aftermarket' for those vbelts.
FYI the part numbers:
1) 99365‑80840 (for fan and alternator)
2) 99365‑21060 (cooler compressor to crankshaft pulley
MoonGT wrote:onnaj wrote:I did extra searching and i did find the numbers!
In ToyoDIY I found the part numbers the first one matches but the second one cooler compressor to crankshaft pulley belt number differs with the one you stated i.e. i found the 90916-02430 which doesn't matches with your stated one 99365‑21060...
Bit confused...
