4AGE 20V BT V-Belt part numbers
onnaj
Postby onnaj » Thu Mar 21, 2013 1:07 pm
Hello,
I'm looking for the parts numbers for the V-belts of a BT. Can't find them on Toyodiy.com.
Anyone who has the numbers and maybe someone has new belts lying around doing nothing? ;)
choi0706
Re: 4AGE 20V BT V-Belt part numbers
Postby choi0706 » Thu Mar 21, 2013 9:04 pm
convert to 16v stuff..
onnaj
Postby onnaj » Fri Mar 22, 2013 4:26 am
choi0706 wrote:convert to 16v stuff..
I won't cause i already have a new oil pump, hydraulic tensioner, timing belt, water pump, etc.
Just looking for the part numbers :)
allencr
Postby allencr » Fri Mar 22, 2013 4:58 am
Wrap a rope around it & go to part house to fit it around their belt sizing thingy or measure the rope yourself. Most belt part # are partially made up from their size in mm or in.
Do not get belts from a dealer.
onnaj
Postby onnaj » Fri Mar 22, 2013 3:46 pm
I did extra searching and i did find the numbers!
I can get them from Mitsuboshi, yes that are the one Toyota uses also, for about 40 dollar or so. The OEM Toyota ones go for about 100 dollar. I go for 'aftermarket' for those vbelts.
FYI the part numbers:
1) 99365‑80840 (for fan and alternator)
2) 99365‑21060 (cooler compressor to crankshaft pulley
MoonGT
Postby MoonGT » Mon Apr 01, 2013 10:51 pm
What is the name of brand that you bought?
MoonGT
Postby MoonGT » Mon Apr 01, 2013 11:05 pm
onnaj wrote:I did extra searching and i did find the numbers!
In ToyoDIY I found the part numbers the first one matches but the second one cooler compressor to crankshaft pulley belt number differs with the one you stated i.e. i found the 90916-02430 which doesn't matches with your stated one 99365‑21060...
Bit confused... :|
onnaj
Postby onnaj » Wed Apr 03, 2013 9:15 am
Bit confused... :|
When i use your number i find the belt for the Carina FF, not the AE111. I think the Carina AT210 was the one with the silvertop, but don´t know that 100% sure.
When i search ToyoDIY with number 99365-21060 i find the right one.
This is the direct search link: http://www.toyodiy.com/parts/xref?s=99365-21060&mE=on&mJ=on
