This is the "V" engine - https://en.wikipedia.org/wiki/Toyota_V_engine - not a whole lot of information....
    The "V" engine designation began in the 1960s, and ended in the 1990s. It began as a 2.6 liter V8, and in its last iteration it was 4.0 liters. Wiki is a bit confusing - in one place it states the V engine was superseded by the UZ, yet in another it says it was superseded by the GZ 12 cylinder. The later would be correct. While the UZ engine line is the next V8 after the V, the UZ was used in different applications then the V was, the GZ replaced the V in the only car to use either - the Toyota Century.
Some more info "gleaned" from the internet... (notice some discrepancies in power between this, and Wiki)
engine type naturally aspirated petrol
Engine manufacturer Toyota
Engine code 5V-EU
Cylinders V 8 in 90° vee
Capacity 4 litre - 3994 cc - (243.729 cu in)
Bore × Stroke 87 × 84 mm - 3.43 × 3.31 in
Bore/stroke ratio 1.04
Valve gear overhead valve (OHV)
2 valves per cylinder
16 valves in total
maximum power output: (JIS net) 164 PS (162 bhp) (121 kW) @ 4400 rpm
Specific output(JIS net) 40.6 bhp/litre - 0.66 bhp/cu in
maximum torque(JIS net) 289 Nm (213 ft•lb) (29.5 kgm) at 3600 rpm
Specific torque(JIS net) 72.36 Nm/litre 0.87 ft•lb/cu3
Engine construction light alloy head & block (reported to be 130 kilos[286#s]) for comparison a 1UZ tips the scales closer to 355#s
compression ratio 8.6:1
Fuel system EFi
bmep (brake mean effective pressure) 909.3 kPa (131.9 psi)(with a BMEP of 131 theres some serious room for improvement)
Maximum RPM unknown… but hemi article alludes to a crank capable of 9000 rpm
crankshaft bearings 5
Engine coolant Water
Unitary capacity 499.25 cc
Aspiration Normal
In my searches for info on this engine, I had heard that an old Hemi book had a few pages on the V engine... after pestering a few of my friends who build V8s... I got this...
Now the BIG downside... Toyota no longer services this engine - all gaskets will need to be custom made
So, I began my search... and it began with Moto! I had asked Moto a few months ago if he knew of any engine importers that might help me. He recommended a few. I tried them, and I also asked Robert @ EP importers - http://www.etsuryu.com . Robert was a great help and found a Toyota V engine for me! To make a long story short - Robert couldn't import the engine for me, so I passed the information (YJ auction) along to an engine importer that came recommended on Facebook. Once the engine gets here, I'll post the engine service with whom I bought my "new" 5V-EU from...
and here it is - scans came from the YJ auction
Robert did help me with 2 other significant purchases... 1 - an original starter for this engine, and 2 - a 5V-EU factory service manual!!
I expect the engine to arrive sometime late spring, or early summer.
A WHOLE lot more to come...
  The 426 Hemi engine by itself weighed over 750#s!!
   The 426 Hemi engine by itself weighed over 750#s!! )
 I've heard a rumor the the V was used in some of the Stadium trucks....  not sure how accurate that is
