OST-053: Massaging a 20V Blacktop
Postby oldeskewltoy » Thu Feb 14, 2019 4:14 pm
My client asked me to overhaul his Blacktop (for his AE86). It comes to me with a spun #2 rod bearing (atypical, in my exp usually it's #4). The rod is toast, and the crank would need to be turned. "Would", not "will". My client isn't a fan of a turned crank, so we have ordered a new one. And as far as rods go, I have a set of re-worked TRD (20mm pins now) rods, that I'm selling him.
here is the head during disassembly
some grunge, but I've seen worse
Here are the cleaned block, head, valves, and associated parts. Using the back of my car as a pick up......
more to come..... :D
kaosboss
Re: OST-053: Massaging a 20V Blacktop
Postby kaosboss » Sun Feb 17, 2019 7:53 pm
What method did you use to get the head so clean?
Postby oldeskewltoy » Tue Feb 19, 2019 7:13 am
kaosboss wrote:What method did you use to get the head so clean?
I work with a couple of machine shops, part of the fees in doing head work is a professional cleaning, and checking the casting for its pressure holding ability - make sure there are no porosity issues
from another forum wrote: Oooh, that's pretty neat.
What are the big advantages of going 20v over the stock 16v head? It seems like a lot of work to import for a mild gain.
There are 2 significant differences. The first is at lower level lifts, the intake side flows much better. At higher lifts, the flow tends to get closer, beginning to equalize. The second major difference is the exhaust size is significantly larger.
With that said... a ported 16V std valve head can be made to do everything, except equal the 20V @ low lifts.
having all the other projects now finished, or waiting on parts, I ficus on the Blacktop head - working the intake side first.
#1 in the right, #2 on the left.
more to come.... :D
Postby oldeskewltoy » Thu Feb 21, 2019 8:40 am
further progress, this time on the exhaust side......
more to come....... :D
Jester_Borris
Postby Jester_Borris » Fri Feb 22, 2019 9:15 pm
Excellent work as alway OST. I’m finally able to revisit my Blacktop project of 7 years ago. This is inspiring - makes me want to get on it.
1986 AE86 - 20V Silvertop 4A-GE w/ Blacktop ECU
Postby oldeskewltoy » Wed Feb 27, 2019 8:06 am
Jester_Borris wrote:Excellent work as alway OST. I’m finally able to revisit my Blacktop project of 7 years ago. This is inspiring - makes me want to get on it.
any inspiration I can help with is all good!
sometimes... it helps to see from a different POV...... I've added a photo to the above multi-panel
for the sharp of eye who follow my work, the above castings are from OST-034, but they still hold true...... as before, and after exhaust porting on a Blacktop head.
More to come...... :D
cincybranr
Postby cincybranr » Wed Feb 27, 2019 3:40 pm
Subscribed! Awesome!!
Postby oldeskewltoy » Thu Feb 28, 2019 8:44 am
from another forum wrote:What is your honest feedback on the TRD conrods for the 20v?
I know i need to rebuild my 20V, not sure if bore walls are STD, if not, big pistons will follow and obviously new conrods (just because).
Not sure what to purchase...
I've had this set of rods for a while... in fact this set's been to Europe and back (sold, and then returned). BUT you don't need to spend BIG money for decent rods. While I have only this anecdotal experience with blacktop rods, this engine's bearings appear to just be old worn out parts - all the bearings were pretty bad. But for the most part OEM rods are plenty strong. As an example of stock rod durability, my smallport is running a 40mm rod journal crank and stock 3 rib 40mm rod journal rods - albeit with new bolts. I'm making 140 ish whp, and I twist it regularly up to 7500+ and it now has over 30k miles on it.
But if you just want better (stronger, and lighter) rods, I usually recommend Molnar Technologies. They run about $450 per set.
Port work continues.... 2 down.... 2 to go
more to come.... :D
Postby oldeskewltoy » Fri Mar 01, 2019 8:59 am
more to come.... :D
Postby oldeskewltoy » Sat Mar 09, 2019 3:04 pm
3 down... 1 to go....
Time to set up the flowbench, and get some #s........
Postby oldeskewltoy » Wed Apr 24, 2019 8:41 am
Well... it has been forever... (well it feels like it).... and it no longer feels like a massage....
A new crank, a new set of rods(Molnar 42/20).... new custom (dome) pistons (11.5:1).....and MRP oil pan.... and the 20V Poncams are currently not available :(
We needed a crank, the first one we bought used... found out all the journals were a few ten thousandths (.000_") too thin... it might have worked for a dry sump race build... but for this engine my client (with my advice) bought a new crank.
The TRD rods (Jorge, your machinist has a good eye...) There was a dodgy bushing in one of the rods... to fix it properly would have required making the small end too thin... so the TRD rods got canned, and a set of Molnars were ordered.
JE Piston has a 11.5:1 piston.....
but... that ratio is with an .040" squish, our target is .032-.035, so I asked them to reduce the domes from 6.5cc, down to 4.2cc.
As far as oil supply, we decided a set of Toda pump gears, and an MRP pan
The Poncams....?????????? They've been delayed twice now... Tomei, and Kelford seem to be out of blanks.... and while Cat cams appear to have blanks, I'm not a fan of the Cat cams 20V cam timing.....
The head is ready for re-assembly.........
more to come.... :D
Postby oldeskewltoy » Tue May 21, 2019 5:11 pm
nearly a month later....
We sent out his crank, and the Toda oil pump gears to get WPC'ed - http://www.wpctreatment.com/
Now that they are back, bearing clearances are set to .0015" for the main bearings, and .0018" for the rod bearings - in the range specified by the FSM.
Additionally we now have a deck (.004" piston above), so the somewhat common .8mm head gasket is getting too thin with our deck - .028", so we have decided to get the Cometic .040"(1mm) gasket. This will allow a slightly more generous .036" squish (versus a .032" squish).
As to our new internals - mass savings of 20 grams... Blacktop stuff is pretty well optimized.
Now that all the machine work specifics have been finalized, this block is getting the Eastwood black coating I first used in OST-050.... so more time between postings.... :roll:
more to come... :D
Postby oldeskewltoy » Wed May 29, 2019 10:15 am
so...... while waiting for the block coating.....
and since the oil pump was going to be opened up for the Toda pump gears.... a little work to "improve" on the OEM unit....
Postby oldeskewltoy » Tue Jun 25, 2019 11:37 am
Thank you Barry!
Kelford finally got 20V cam blanks, and so my client ordered a set of MRP/Kelford custom cams for 20V.
Here is the cam card for the Tomei 20V Poncams...
Note the differences...??
meanwhile.......
The block has another week before it can go back to the shop for assembly
