jondee86 wrote:On the USDM GTS the tacho gets its signal from the black wire on the igniter.
The SR5 will get a signal direct from the coil negative. The black wire finds its
way to the big square(ish) plug on the firewall behind the engine, and from
there to the OEM tacho.
According to this diagram...
... all you need to do is connect the black wire (that leads to the tacho) to the
violet wire out of the tach adapter. Note that the tach adapter needs its own
key-switched 12V supply and chassis ground.
