While I've seen a few poor smallport castings.... this one is a pretty good casting, with decent chambers, and pretty good port-bowl alignment. What it doesn't have is a good short radius..... on ALL of the bowls....
more to come....
from another forum wrote:I'll bite WTF does thanking Stalin for your happy childhood have to do with this? Try to avoid sniffing solvent my friendmg:
oldeskewltoy wrote:
Rogue-AE95 wrote:The before & after of the exhaust ports is especially noticeable!
I've not been a fan of the Supertech kit. One reason....
oldeskewltoy wrote:I checked valve protrusion through the retainer, I have .025" on the exhaust side, and .030"+ on the intake side... so that concern is no longer a concern.....
Rogue-AE95 wrote:oldeskewltoy wrote:I checked valve protrusion through the retainer, I have .025" on the exhaust side, and .030"+ on the intake side... so that concern is no longer a concern.....
Did you have to use Bigport (or Mercedes?) keepers? Was this customer also using used OEM valves, or Supertech valves?
I'm still debating whether to sell off my Supertech valves, especially (as noted in that topic linked above) that I would be using OEM keepers and retainers.
from another forum wrote:To be fair, the Supertech seat (shim) is "designed" around the dual spring configuration.
