20V ST AFM specs
20V ST AFM specs
Does anyone have the actual ohm specs that the 20V silvertop AFM is supposed to be? Been searching around the web but nothing. I read that you can use the Camry 3SFE AFM as a substitute, but it would be nice to measure and compare. I made the mistake of using my original 4AGE one, it runs, but not very nicely .
- Sprite
Re: 20V ST AFM specs
Wish I knew the testing specs for you but I have also read that the 89 - 91 Camry one will work.
Rick
I found a thread on another site that said...
3SFE 2 liter engine apparently, and the AFM should be dirt cheap from the junkyard.
So probably easier to get one and try it out than find test specs for a car that AFAIK
didn't ever have an English language service manual. Besides, mr220v says it works![Smile :)](./images/smilies/icon_e_smile.gif)
... the 4cyl camry 88-91 would work part number 22250-74101
Thanks. I wish I knew more authoritatively. I picked one up, but I can't tell if it really works better than the 16v one or if its just wishful thinking.
Itd be nice if someone out there has one and measured it for us.
