piston question
hachiroku ae86
piston question
Postby hachiroku ae86 » Fri Feb 15, 2013 3:18 pm
so i picked up a 20v ST block and was wandering if i have to swap out the pistons to 16v pistons to run it with a 16v head or can i run the 20v pistons with a 16v head? thank you
Andrew Goodluck
email- hachitruenoae86@gmail.com
paypal- teenmob2@yahoo.com
cell- 909-697-7094
85coupe gtsr5 DDDM(dily driven drift missle)
98 ford f-150 DD blown up
HASport AE86
Re: piston question
Postby HASport AE86 » Fri Feb 15, 2013 5:08 pm
You can run the stock silvertop bottom end with the stock 16v head. The ST pistons are junk though when paired with the head, valve reliefs are way off etc etc. It's called a 1620 engine. Just a heads up, you can get high comp 16v pistons from rockauto for $84 for the set of four. Built a motor a few months ago like that. ST bottom end, Highcomp pistons, Low comp head w/ Low comp cams.
SwangBiz Corolla Chassis Parts and F20/F22C/4AGE Wiring Services
(we build stuff, I solder wires, we race corollas, then we get drunk)
Proud Supporter of JSPfab.com, BattleGarage, and Solo8 LED Solutions
hachiroku ae86
Re: piston question
Postby hachiroku ae86 » Sat Feb 16, 2013 2:58 pm
HASport AE86 wrote:You can run the stock silvertop bottom end with the stock 16v head. The ST pistons are junk though when paired with the head, valve reliefs are way off etc etc. It's called a 1620 engine. Just a heads up, you can get high comp 16v pistons from rockauto for $84 for the set of four. Built a motor a few months ago like that. ST bottom end, Highcomp pistons, Low comp head w/ Low comp cams.
what year and what car did you look up on rockauto and what brand pistons? thank you
Andrew Goodluck
cell- 909-697-7094
Re: piston question
Postby oldeskewltoy » Sat Feb 16, 2013 3:07 pm
1991 Corolla GTS... should get you the correct piston listings... the only one I saw I'm sure are high comp pistons are - DNJ ENGINE COMPONENTS Part # P927. Check your block BEFORE you order.... your block MAY need to be overbored, so buying standard bore pistons wont help you........ they do offer 2 overbore sizes... .020" is 1/2mm oversize, .040" is 1mm oversize
hachiroku ae86
Re: piston question
Postby hachiroku ae86 » Tue Feb 19, 2013 11:48 am
also will i have to adjust the valves or will they be fine
Andrew Goodluck
cell- 909-697-7094
HASport AE86
Re: piston question
Postby HASport AE86 » Tue Feb 19, 2013 11:54 am
hachiroku ae86 wrote:also will i have to adjust the valves or will they be fine
just check that the valve clearance is within tolerances, if not ya gotta buy some shims
johnny_86
Re: piston question
Postby johnny_86 » Thu Feb 28, 2013 7:41 pm
Hey I was wondering if u can post up a link to those high comp pistons I just went to the dealer today and the pistons were $110.00 each
johnny_86
Re: piston question
Postby johnny_86 » Thu Feb 28, 2013 7:46 pm
What r the compression ratio on the redtop engines
