These gears are NOW BACK IN STOCK!
PRICE DROP TO $128.00
PRICE DROP TO $128.00!
http://www.shopnonstoptuning.com/store/ ... G86K_.html
Colors at no charge: red, blue, black, gold, purple
Include a note with order for preferred color
Product Description
NonStopTuning Adjustable Cam Gears allow for the tuning of camshaft timing to effectively increase engine performance and tailor power output for various race applications. Compatible with either OEM or aftermarket camshafts, adjustments can be made to tune the eninge’s power band to the optimum range for each particular application.
NST Adjustable Cam Gears feature CNC machined outer rings paired with hard anodized 6061-T6 center hubs to ensure the most durable and best fitting design possible. The NST Adjustable Cam Gear is one of the few available with the quality of a factory fit, finish, and craftsmanship.
Standard color: Red
Extra Colors: red, blue, black, gold, purple
SPECS AND BENEFITS
• Increased adjustability of camshafts
• CNC machined outer rings for exceptional belt fitment
• Anodized 6061-T6 aluminum center hubs
• Hex bolts and washers used to prevent “slippage”
Many thanks everyone, best of luck with all your projects!
