I'm planning to swap in 1zz coil on plug. Have coils in hand, SQ Engineering bling for mounting is on the way.
Have a CAN bus Bosch LSU 4.9 wideband in the mail.
The main goal of my impending project is to use a Link G4+ Monsoon ECU to run the BT. I have a Toyota ecu socket in the mail to make an adapter pigtail, kinda want to avoid hacking up too much of the existing wiring. Eventually I'd like to put on a mild cam (keeping vvt, it sounds so burly) and someday maybe run 3-5lb boost.
I'm fishing for tips here. I have heard there are issues with setting spark advance safely for first startup, read conflicting info about the cam sensor under the distributor (need 24 tooth cam+1 tooth crank, maybe the reluctor is too weak to provide reliable cam angle etc) and generally have a little doubt about the best way to achieve success. Also the Monsoon doesn't have a knock input
Who's running Link g4/g4+ here? This is my first standalone attempt and I'm looking to learn by others where possible and experience everywhere else. A base map would be awesome, I'm not sure where I should be starting with for safe timing and sane VE. Anyway, I've been reading for weeks, watched a bunch of HPA videos and attended a live tuning webinar on Link g4+'s. I'm new to Toyota (Subaru's only all 14 years I've had a car) and would greatly appreciate any aftermarket EMS advice you experts are willing to impart!
