What timing blt is used for the 7age 20v?
I know it not the porsche one. Any one else know? Its a 7age 20v BT
gaijin_rokurunner
Re: What timing blt is used for the 7age 20v?
944 belt...thought u already had a 7age up and running ?.......here is a good write up on doing a 7age swap..http://www.ae82.net/showthread.php?526- ... e-for-AE82
I do but from what I read when using the BT 20v head you cant use that belt
greenae102
v33sonata wrote:I do but from what I read when using the BT 20v head you cant use that belt
Your absolutely right, it the Renault R21 2.0i Turbo 86-95 Timing Belt. I had to order mine from across seas on ebay as no belt in the US that i could find matches it. 16v cam gears are further apart than the 20v so a smaller belt is difinitely needed. i used the 7a tensioner setup on mine tho so im not sure it it will be different with the 20v tensioner
green ae102
7ag 20v installed
my 4 door will own your 2 door!
7ag 20v installed
greenae102 wrote:v33sonata wrote:I do but from what I read when using the BT 20v head you cant use that belt
thank you!
