T50 Transmission with SR5 bellhousing: $300
Transmission is in great condition shifts smoothly. Same trans as the GTS version. You just need to swap to a 4age bellhousing.
*Comes with everything pictured but the starter and crossmember* If you need the starter and crossmember i can add it for $100 extra*
Sr5 manual complete driveshaft. Can be shortened to accomodate the GTS differential. $80
USDM Front and rear bumpers $100
Complete 4-AC motor. Comes with all the accessories needed but im keeping the harness. Unknown mileage. Carburetor needs a rebuild but it runs good and smooth. Engine was recently swapped so that is why i dont know the mileage on it. $400
