Hey all,
I replaced the control arms and wanted to know if I need to tighten them with the car on the ground, or if I can do it when jacked up? The manual doesn't seem to get much into this topic. Just was curious due to new bushings and such.
Control Arm Pre-Load? When to tighten? AE86
Re: Control Arm Pre-Load? When to tighten? AE86
Tighten when on the ground or on a ramp with the weight of the car on the wheels.
It's less of an issue with poly bushings and heim joints since the bushing crush tube doesn't have teeth on the ends, but I still recommend tightening them with the weight of the car on the wheels.
You can go a step further though if there's a curb at the end of the driveway or a speed bump in the street right in front of the house. Leave the bolts slightly loose and slowly drive up/down the curb (or over the speed bump) a few times which will fully settle the suspension. Then tighten the bolts. Don't actually drive down the street or go above a a few mph with the bolts loose!
