Hood fitmentJust got word from Seibon today about the missing holes on the hood for the hooked pins. They told me to use a stepped drill bit to make two circles and a dremel to connect the two circles. I measured out the holes and they are ~18mm wide, that's ~.70inch, so the closest drill bit size would be 11/16". Man I absolutely hate the US tool sizes sometimes.
Anyways, I cheaped out on the bits because cheap ones will probably do the job just fine in this case. Bought the following from from Harbor Freight:
- "Dremel"-like accessory pack with tons of bits
- Shallow stepped drill that went up to 11/16 without going too deep
- Lightsaber (more on this later)
Hood protectionI'm also looking at various heat shielding materials for the underside of the CF hood as I heard you could "cook" the CF from below because of radiant heat from your exhaust header/manifold. I still want to make some metal heat shield for the header and/or re-ceramic coat them but that can wait.
For rock chip prevention, I'm looking at various types of films and looking at places that would install them. I heard really good things about Xpel ULTIMATE and its "self-healing" properties, so I'm leaning towards that.
Seat mountThanks for the input shagymc! I'm curious about your custom mount. Is it a two piece bracket (like FG / T3) or a one piece like Bride RO-type? Does it have sliders?
And thanks for mentioning the T3 rails. I've also looked into T3's side mount bracket system previously. I like the bracket piece. The side mounts they provide wouldn't work that well when you add sliding rails in between because the width of the side mounts is tied to the width of the slider. If T3's side mounts provided side to side adjustment like planted side mounts, that would be most ideal.
But that does give me an idea:
Option AT3 2 piece bracket
Some two piece slider(bride? or perhaps I can repurpose the Corbeau by chopping the unlock mechanism handle to widen the tracks) on top of the bracket
T3 side mounts on top of the sliders
Alternatively I can try the following:
Option BT3 2 piece bracket
Some slider wide enough that we can adjust the side mount width to work.
Planted or similar wide base side mount
Option CBride RO bracket/slider combo
A and B would probably be the most low solution
B will be most expensive, C next, and A being least expensive.
