So asb15 and my missle didn't happen, that sh!+ got expensive really quick and just had a lot to do for a missle to survive an event like that.
Going to slow it down and knock this out when I can and get a chance to do some work on it...but still keep it "missile". Probably just going to do things with whatever little money  I have so definitely keep it a budget and mild build.
Part numbers list I'll be using that other members have used time and time again, and now I'll be getting a chance to use and share these parts as well. I just type the name and part number in google, and search for whatever company can ship it fastest lol.
Brakes and Rotors~ Porterfield R4S (front pads)
~ Hawk HPS HB203F-550 (rear pads)
~ RPM slotted rotors ( front and purchased 2011, just now putting them to use)
~ Centric solid rotors (rear rotors)
*Battle Garage
~ steel braided brake lines (they have a different name but BG has them in stock)
Suspension and Steering (feel free to correct me on part numbers)
 * KYB AGX shocks
~ 765015 (sw20 front shock setup)
~ 743019 (camaro rear shocks)
* Beck/Arnley bellows
~ 103-2683 & 103-2206 (mr2 manual rack swap)
* Beck/Arnley tie rods
inners ~ 101-4081
outters ~ 101-3707
* Prothane bushings (add -bl at end for black bushings)
~ 18-1203 (strut rod/ tension rod)
~ 18-210 (lower control arm)
~ 19-421 (sway bar end link and bushings)
~ 18-401 (sway bar bushings only)
~ 18-702 (manual r&p bishings; I'm going to use the T3 bushing for the power to manual rack conversion on the passenger side and have a new Prothane bushing on the driver side)
* Moog ball joints
~ k9083
*Techno Toy Tuning
~ T3 camber plates
~ T3 strut tube spacer
~ T3 big port itb adapter
~ T3 crank pulley (used, had it on my 20v)
~ T3 water pump pulley (used, had it on my 20v)
~ T3 crank trigger wheel
*Battle Version*
~ Negative Roll Center Adjusters (going to use them off my other car so used quality parts for sure)
*Dmac
~ offset manual rack spacer
*Aisin
~ CMT-038 (clutch master cylinder)
~ BMT-043 (brake master cylinder)
Engine Setup*HKS
~ 3302-ST029 (Sport exhaust, single tip)
~ 2201-RT004 (4AG 16v valve springs)
*SQ-Engineering
~ 100mm silver top velocity stacks
~ pipercross filter adapter
~ 16v dizz yblock off
*Arp
~ 203-6001 (rod bolt kit)
~ 203-5001 (mail bolt kit)
Wicked Sick Goodies*Toyota
~ 31321-53010 (pad pedals, also used in lexus is300)
How I like to start when I work on this missle.
Healthy breakfasts, this is how I roll!
My old ae101 hope can still be salvageable.  Short block going to be used, 16v head and itbs.
Just this sucker is getting used. Head with cams, gears, valves is for sale. Just sayin'
My Polish buddy , Jeff, going to give me a hand with the engine build. Homeboi gets down with engines so someone that's local and I can trust with the work.
Marking everything just to be on the safe side.
Ugly, I know. And I put a good beating on this.
Cleaned the pistons up a bit to mark them. Won't be using the pistons but good for practice.
This is what happened after doing hot laps on HTM.
Hope I can still use the crank. I'll find out after I take it to the machine shop...
Con rods look fine.
This however, not so fine.
The springs are already on the missle, just got some sw20 front kyb agx shocks in the mail along with t3 strut spacers and godspeed sway bars that will be getting installed. Springs not to stiff so sways and maybe a few extra bars should help stiffen the ride to try and match my other hachi project. The sr20 corolla has Parts Shop Max Pro Coilovers and I love that suspension setup. This project is more of a budget build so a few new bushings and new parts will help keep this 84 corolla stay sturdy.
I'll STFU and post pics.
Shocks came in while I was working on missle
Suspension stuff is out and so is the subframe.
Old and new. Kyb agx sw20 front shock setup. Been curious about these, now im about to find out if I like them or not.
Not so gangster rolling on cut springs and blown shocks. Previous owners work.
Cleaned and rattle canned, also did a clear coat. Not a fan of the gunk this 84 has been collecting.
T3 strut tube spacers
KYB part number - 765015
How the settings get explained lol
Always wondered how these got adjusted. Never got a chance to look at these really close.
One down, one more to go. Going to use my sr corollas Battle Version NRCA and purchase the t3 camber plates.
Godspeed sways. Cant beat the price and just a solid metal....I hope. I'll find out how well these hold up come track day.
Clean clean clean, sounds like a hassle and work but makes working on a car a lot easier a much nicer.
Comparison - sr5 and Godspeed front sways
Yup, 7 11 diet.
Bout to go HAM on this!
Got help from the homies, Purple Power and brush. They get down af!
Goint to scuff and paint also. Left some bolts and nuts in the chemical cleaning bucket so ill check that out when I get closer to assemble everything.
