need help with all the vacuum lines and water lines?
runkillerrabbit
Postby runkillerrabbit » Tue Feb 12, 2013 11:28 am
im installing the tvis and i dont know where some of the lines go to
and what the hell is this?
if anyone could provide the link to where the pictures of the vacuum lines are ... link me?
or pic me? i need under the tvis where 2 water lines go in to the intake manifold. i dont know which water line goes to wich one. does it matter?
also can just loop the in and out for the heater core? i dont have a heater anymore.
thanks
FIDM fashion design
ITT tech electrical engineer
FJC Fullerton automotive program
R2D2 build log
Jacare
Re: need help with all the vacuum lines and water lines?
Postby Jacare » Tue Feb 12, 2013 12:29 pm
Ya what is that thing. I have it too and it sounds like its leaking all the time.. I almost partially blame it for failing smog
Postby oldeskewltoy » Tue Feb 12, 2013 1:59 pm
Jeonsah
Postby Jeonsah » Tue Feb 12, 2013 3:00 pm
I do not remember the name of it. Normally devices like that have to do with raising the idle under an electrical load to compensate. So for example when you turn on your air conditioning. This will cause the idle to dip down. So those devices normally detect this and let in a little bit more air to raise the idle.
runkillerrabbit
Postby runkillerrabbit » Tue Feb 12, 2013 5:02 pm
ok good it has to do with the ac... i deleted my ac so i m guessing i can block this line off?
FIDM fashion design
R2D2 build log
Jeonsah
Postby Jeonsah » Tue Feb 12, 2013 6:17 pm
I am unsure if its related to the AC. I was just giving an example. Its disconnected on my car and Im not having issues. However, I would keep it connected. If you dont know what it is, keep it connected :p. As far as the lines under the throttle body goes, heres some information that will help you out:
http://www.toymods.org.au/forums/tech-c ... pipes.html
It looks like it is related to the AC and PS assemblies. If you dont have either, you can loop them. I have them looped on my car but I dont remember how(My car is somewhere else).
EDIT- just found out that thing next to the AFM is the VSV(vacuum switching Valve).
It looks like it is an electrically controlled valve that lets in extra air to the engine behind the throttle body blade. Im am unsure of when it is actuated though. Heres a good picture for everyone to follow when wondering how these things are hooked up. I took it from my personal FSM:
Vic
MisterJerk
Postby MisterJerk » Tue Feb 12, 2013 7:00 pm
The electrical idle up valve, with the green plug. its to raise the idle a bit to compensate for electrical load, lights, blinker, etc. I disconnected mine and capped the vacuum ports.
The three ports visible in your pic are vacuum for power steering and a/c. if you dont have either, cap them. do not loop.
the 2 that point down are the water in and out for the iascv, connect them in the way that makes sense when you look at the water pipes and the ports on the throttle body, more forward pipe goes to the front port, etc.
Jeonsah
Postby Jeonsah » Tue Feb 12, 2013 8:19 pm
MisterJerk wrote:The electrical idle up valve, with the green plug. its to raise the idle a bit to compensate for electrical load, lights, blinker, etc. I disconnected mine and capped the vacuum ports.
*2 thumbs up*
MisterJerk
Postby MisterJerk » Fri Feb 22, 2013 5:31 am
Did you get this thing running?
Updates, man. inquiring minds wanna know.
runkillerrabbit
Postby runkillerrabbit » Fri Feb 22, 2013 8:34 am
o im sorry i didnt know hahah
im sourcing 2 damaged zenki harness so i can wire everything up
should be cranking it over next couple of days!
FIDM fashion design
R2D2 build log
MisterJerk
Postby MisterJerk » Fri Feb 22, 2013 10:35 am
w00t! Hopefully they arent damaged in the same spot. lol. if you give up on the wiring, dr.tweak can make a 16v harness too.
runkillerrabbit
Postby runkillerrabbit » Fri Feb 22, 2013 10:48 am
im actually a electrical engineer drop out. so i just need to know the wire colors and the actualy schematic of it. the FSM wiring diagram is so vague. im gunna actually make my own wiring diagram with pics and everything. and make my own wire loom and just reuse the connectors
FIDM fashion design
R2D2 build log
MisterJerk
Postby MisterJerk » Fri Feb 22, 2013 12:40 pm
might want to get new connectors for the injectors(usually the first to break off)
I used these: http://www.summitracing.com/parts/avm-30-2020
runkillerrabbit
Postby runkillerrabbit » Fri Feb 22, 2013 4:16 pm
MisterJerk wrote:might want to get new connectors for the injectors(usually the first to break off)
good to know!
FIDM fashion design
R2D2 build log
