AE86 Project - Restore / S2K swap
2jzmk3
Postby 2jzmk3 » Wed Jun 04, 2014 12:23 pm
These are old pics, i dont remember ever posting them. The car has literally sat in my garage for 2 years since completion, and i decided a couple weeks ago to redo some stuff and get it out from collecting dust. I had a couple other projects, and i had been neglecting this one. A few people already know about this project and want to be updated so I figured starting up a thread would be the easiest way. Anyway for those that don't know what this project is, The original setup was a 2004 Honda S2000 engine with a Comptech Super Charger into my 1986 Toyota Corolla GTS w/ a complete restoration on the Chassis.
I decided to change some stuff recently, and do a small turbo instead with some some Wiring updates and changing the ECU from AEM to MoTeC.
OEM motor out.
Interior pulled out.
12 Nissan GTR Black Edition
10 Toyota Sequioa Platinum
91 Toyota Supra
86 Toyota Corolla Ae86 s2k swap
2jzmk3
Re: AE86 Project - Restore / S2K swap
Postby 2jzmk3 » Wed Jun 04, 2014 12:27 pm
Chassis off to sandblast
motor - trans in. stitch welded
91 Toyota Supra
marley4us
Postby marley4us » Wed Jun 04, 2014 1:42 pm
Wow that is the motor swap to the T I originally waned to build, KILLER set up man! That thing will fly.
1994 4runner (The truck)
2jzmk3
Postby 2jzmk3 » Thu Jun 05, 2014 11:27 am
91 Toyota Supra
yellowsnow4free
Postby yellowsnow4free » Thu Jun 05, 2014 7:15 pm
Wow 2jzmk3, your car looks great! :D
I'd tell you to "keep up the good work", but I'm sure you will! :)
Good luck with your project though ;)
2jzmk3
Postby 2jzmk3 » Sat Jun 07, 2014 11:19 am
Did Cusco Nissan S13 suspension, so had to change the geomerty of the suspension. a little. everything is cusco, all the braces and diff, and suspension.
91 Toyota Supra
2jzmk3
Postby 2jzmk3 » Sat Jun 07, 2014 11:20 am
Did nissan 300zx brakes
91 Toyota Supra
rekik
Postby rekik » Mon Jun 09, 2014 7:56 am
FANTASTIC WORK! what's the spec on the wheels to fit the 300zx setup? Thanks.
2jzmk3
Postby 2jzmk3 » Thu Jun 12, 2014 1:10 pm
rekik wrote:FANTASTIC WORK! what's the spec on the wheels to fit the 300zx setup? Thanks.
They are 15X10 in the rear and 15X8.5 in the front black chrome J-Line 5RL2 2 step lip..
91 Toyota Supra
2jzmk3
Postby 2jzmk3 » Fri Jun 13, 2014 8:13 am
Here is how it sat about 3 weeks ago.
91 Toyota Supra
sekang0
Postby sekang0 » Sun Jun 15, 2014 2:18 am
Wow. Very well done!
'85 GT-S project since 2010
Deuce Cam
Postby Deuce Cam » Sun Jun 15, 2014 12:00 pm
Looks great!
Fyi that style of hood pin has a bad track record. I tried a set a few years back after a few gurus told me not so use them because they've seen them break. After initial installation I was fiddling with them trying to get the height right, and I broke a fastener in half when lightly hand tightening adjustment nuts. The metal was porous on the inside of the stud!
2jzmk3
Postby 2jzmk3 » Wed Oct 29, 2014 9:47 am
So now that the S/C and everything is off. put a factory style radiator back in, started fabbing the exhuast manifold. turbo is a precision 6262 with twin tial 38 mm wastegates
91 Toyota Supra
2jzmk3
Postby 2jzmk3 » Wed Oct 29, 2014 9:49 am
Should have that part done this weekend, pretty much done with everything else. So maybe a couple more weeks and it will be back on the road.
91 Toyota Supra
IndiaDorifto7
Postby IndiaDorifto7 » Thu Oct 30, 2014 5:24 pm
Once the car is complete, you'll be saying, "VTEC just kicked in yo!"
mtmetzger
Postby mtmetzger » Thu Dec 18, 2014 12:37 pm
Which rear end are you running? Also, can you post a picture and any details you have of the drive shaft? I'm not sure what I'm going to run in my F22c car just yet.
2jzmk3
Postby 2jzmk3 » Fri May 29, 2015 8:07 am
mtmetzger wrote:Which rear end are you running? Also, can you post a picture and any details you have of the drive shaft? I'm not sure what I'm going to run in my F22c car just yet.
just the OEM rear end, and a cusco diff. i hope i dont have to replace it. but we will see.
91 Toyota Supra
2jzmk3
Postby 2jzmk3 » Fri May 29, 2015 8:17 am
building the exhuast. going to be 3.5in
Dont mind the fuel pump setup. im changing all that.
91 Toyota Supra
2jzmk3
Postby 2jzmk3 » Fri May 29, 2015 8:18 am
all the fab done. marking everything for coating.
91 Toyota Supra
graycob
Postby graycob » Fri May 29, 2015 9:40 am
This is what dreams are made of..
86SPL
Postby 86SPL » Sat May 30, 2015 11:45 am
what would one expect to pay for the mods that you've done?
grappletech
Postby grappletech » Sat May 30, 2015 1:42 pm
This is a pretty ridiculous amazing build... good luck moving forward
87 SR5 Coupe Shell. (Sold)
86 SR5 Hatch Shell
86 GT-SR5 Coupe 20v Swap
2jzmk3
Postby 2jzmk3 » Mon Jun 01, 2015 6:48 am
86SPL wrote:what would one expect to pay for the mods that you've done?
never added it up. but its alot. If you have to really add it up, you shouldnt be attempting a build. especially a ground up build.
91 Toyota Supra
2jzmk3
Postby 2jzmk3 » Tue Jun 30, 2015 9:07 am
Coating all done.
91 Toyota Supra
