piston question
hachiroku ae86
piston question
so i picked up a 20v ST block and was wandering if i have to swap out the pistons to 16v pistons to run it with a 16v head or can i run the 20v pistons with a 16v head? thank you
Andrew Goodluck
email- hachitruenoae86@gmail.com
paypal- teenmob2@yahoo.com
cell- 909-697-7094
85coupe gtsr5 DDDM(dily driven drift missle)
98 ford f-150 DD blown up
cell- 909-697-7094
- HASport AE86
Re: piston question
You can run the stock silvertop bottom end with the stock 16v head. The ST pistons are junk though when paired with the head, valve reliefs are way off etc etc. It's called a 1620 engine. Just a heads up, you can get high comp 16v pistons from rockauto for $84 for the set of four. Built a motor a few months ago like that. ST bottom end, Highcomp pistons, Low comp head w/ Low comp cams.
hachiroku ae86
Re: piston question
HASport AE86 wrote:You can run the stock silvertop bottom end with the stock 16v head. The ST pistons are junk though when paired with the head, valve reliefs are way off etc etc. It's called a 1620 engine. Just a heads up, you can get high comp 16v pistons from rockauto for $84 for the set of four. Built a motor a few months ago like that. ST bottom end, Highcomp pistons, Low comp head w/ Low comp cams.
what year and what car did you look up on rockauto and what brand pistons? thank you
Andrew Goodluck
cell- 909-697-7094
cell- 909-697-7094
Re: piston question
hachiroku ae86 wrote:HASport AE86 wrote:You can run the stock silvertop bottom end with the stock 16v head. The ST pistons are junk though when paired with the head, valve reliefs are way off etc etc. It's called a 1620 engine. Just a heads up, you can get high comp 16v pistons from rockauto for $84 for the set of four. Built a motor a few months ago like that. ST bottom end, Highcomp pistons, Low comp head w/ Low comp cams.
1991 Corolla GTS... should get you the correct piston listings... the only one I saw I'm sure are high comp pistons are - DNJ ENGINE COMPONENTS Part # P927. Check your block BEFORE you order.... your block MAY need to be overbored, so buying standard bore pistons wont help you........ they do offer 2 overbore sizes... .020" is 1/2mm oversize, .040" is 1mm oversize
hachiroku ae86
Re: piston question
also will i have to adjust the valves or will they be fine
Andrew Goodluck
cell- 909-697-7094
cell- 909-697-7094
- HASport AE86
Re: piston question
hachiroku ae86 wrote:also will i have to adjust the valves or will they be fine
just check that the valve clearance is within tolerances, if not ya gotta buy some shims
Re: piston question
Hey I was wondering if u can post up a link to those high comp pistons I just went to the dealer today and the pistons were $110.00 each
Re: piston question
What r the compression ratio on the redtop engines
