Control Arm Pre-Load? When to tighten? AE86
genki86x
Postby genki86x » Wed Feb 24, 2016 12:36 pm
Hey all,
I replaced the control arms and wanted to know if I need to tighten them with the car on the ground, or if I can do it when jacked up? The manual doesn't seem to get much into this topic. Just was curious due to new bushings and such.
Re: Control Arm Pre-Load? When to tighten? AE86
Postby totta crolla » Wed Feb 24, 2016 1:38 pm
Tighten when on the ground or on a ramp with the weight of the car on the wheels.
Postby Deuce Cam » Wed Feb 24, 2016 2:11 pm
It's less of an issue with poly bushings and heim joints since the bushing crush tube doesn't have teeth on the ends, but I still recommend tightening them with the weight of the car on the wheels.
You can go a step further though if there's a curb at the end of the driveway or a speed bump in the street right in front of the house. Leave the bolts slightly loose and slowly drive up/down the curb (or over the speed bump) a few times which will fully settle the suspension. Then tighten the bolts. Don't actually drive down the street or go above a a few mph with the bolts loose!
