Crono's F20 Swap!
Crono0001
Crono's F20 Swap!
Postby Crono0001 » Thu Nov 14, 2013 6:29 am
*cough*
ronny
Re: Bought this recently
Postby ronny » Thu Nov 14, 2013 10:33 am
Rays - Project Mu - TE37 club
BLUE MOON / CUSCO
AE86fightclub.com
PM me for Contact
kendallspower
Postby kendallspower » Fri Nov 15, 2013 8:46 am
:lol:
Last edited by kendallspower on Sun Jan 05, 2014 12:47 pm, edited 2 times in total.
AZNWOKZ
Postby AZNWOKZ » Fri Nov 15, 2013 10:03 pm
The Feels of hitting dat V-Tec Bro
Oliver
Postby Oliver » Sat Nov 23, 2013 2:07 pm
Dude, they sent you the wrong motor! I hope you get your money back!
HingaSPL
Postby HingaSPL » Sat Nov 23, 2013 2:35 pm
Blasphemy
Crono0001
Postby Crono0001 » Thu Nov 28, 2013 2:01 pm
Still looking for wiring harness and a supra rear end.
Crono0001
Postby Crono0001 » Sat Dec 14, 2013 2:40 pm
Mr.Fujiwara
Postby Mr.Fujiwara » Thu Jan 02, 2014 9:51 am
nice i saw your car in person Efrin is working on it right?
from suspicious garage? i went with a buddy to buy a
s13 dash from him cool guy
Old username: Charskiezz
20V BT: Traded For F20c Swap
Crono0001
Postby Crono0001 » Thu Jan 02, 2014 2:09 pm
Mr.Fujiwara wrote:nice i saw your car in person Efrin is working on it right?
Yup.
Just secured myself a supra rear axle. Very excited.
Takaaaa
Postby Takaaaa » Thu Jan 23, 2014 11:51 am
cool. look forward to seeing more
Crono0001
Postby Crono0001 » Tue Jan 28, 2014 11:06 am
So I'm contemplating either cutting off the SR5 mounts and welding it onto the supra, or getting some custom 4-links made.
Thoughts?
Postby Deuce Cam » Tue Jan 28, 2014 11:46 am
T3 has a 5 link that supposedly makes it a direct swap. Look under their ae86 suspension section. BUT, I'm not sure if the spring and shock mount locations differ between them. IF they do it might be an issue.
If it was me I'd cut/weld on ALL the ae86 pickups, but only because I'm picky (I'm also not big on heim joints). Did he quote you on the labor cost for that? I can't imagine it's cheap.
Making your own links would be the least expensive, but that's probably only the case if you piece everything together yourself. (Again, still not sure about the springs/shock mounts.)
Crono0001
Postby Crono0001 » Tue Jan 28, 2014 12:06 pm
https://technotoytuning.com/toyota/ae86 ... r-end-swap
I saw the T3 setup. But since my 86 is going to be a daily driver, I'm not sure if I want my spine shattered every bump I go through :P
Anyone have experience with the ride quality?
Postby Deuce Cam » Tue Jan 28, 2014 12:24 pm
I noticed a little more gear noise after installing the t3 panhard, but didn't detect any added vibrations/harness compared to prothane poly bushings. I have no experience yet using heims on the 4 links but I imagine it's loud and harsh :lol:
milchmann
Postby milchmann » Tue Jan 28, 2014 6:17 pm
Noise and vibrations will be pretty noticeable. Harsh though ... not directly from the 4 links, it depends on the springs and shocks you are running with. Rubber and Urethane bushings are for all intent and purpose springs, urethane just has a higher spring rate. They absorb deflection. Since the live axle is un-sprung all of the deflection will be forced through your springs since it will not have any where else to go with the spherical bushings (heim joints etc). If you have soft springs you will have a lot more wheel hop than before though, and the rear end will be jumpy / a little scary.
Crono0001
Postby Crono0001 » Tue Jan 28, 2014 8:25 pm
Don't want any of that. I am a decent driver, but don't want to be dealing with that all the time.
I guess cutting and welding is the way to go. Thanks guys! Stay tuned for more updates.
Crono0001
Postby Crono0001 » Thu Feb 06, 2014 10:07 pm
John H.
Postby John H. » Sun Feb 09, 2014 10:38 am
Clouds
Postby Clouds » Sun Feb 09, 2014 11:56 am
John H. wrote:Image
Success. That is all.
stevegolf
Postby stevegolf » Sun Feb 09, 2014 4:57 pm
I like where this is going
Crono0001
Postby Crono0001 » Tue Feb 11, 2014 8:31 am
Perhaps I'm confused,
what was the point of me getting meme'd?
Postby Deuce Cam » Tue Feb 11, 2014 8:38 am
He's referring to the first couple posts lol...
Crono0001
Postby Crono0001 » Tue Feb 11, 2014 12:32 pm
*shrug*
Reliable power. Can't ask for more than that.
SoyKraut
Postby SoyKraut » Wed Feb 12, 2014 3:16 am
That looks like a win to me.
Crono0001
Postby Crono0001 » Wed Apr 02, 2014 8:52 pm
Ahoy there! Pictures galore!
All work done by Suspicious Garage:
https://www.facebook.com/pages/Suspicio ... 9643564146
SR5 rear end with furniture cut off:
Supra rear end with furniture attached:
I wonder what goes here?
Supra rear end installed:
Picked this up:
Another engine bay shot:
Shiny!
New gas tank:
Also got the following items from Vern:
Crono0001
Postby Crono0001 » Wed Apr 02, 2014 8:53 pm
Could I have this moved to Member's Build Up Logs?
Crono0001
Re: Crono's F20 Swap!
Postby Crono0001 » Wed Apr 02, 2014 9:05 pm
Can't forget these!
AIRWOLF
Postby AIRWOLF » Sun Apr 06, 2014 1:57 am
are you worried about the F20c causing a change in the suspension geometry / handling?
UCSB Alum
steezedae
Postby steezedae » Sun Apr 06, 2014 9:02 am
clean
