BATTLE GARAGE-RS 20v, 16v, TRD, and Interior Parts
BOXER4BG_RS
Postby BOXER4BG_RS » Wed Feb 06, 2013 8:07 pm
Hello everyone, my name is Alex "BOXER4BG_RS" from Battle Garage Racing Service.
Letting everyone know that we are now stocking 20v and 16v maintenance parts and also TRD and Interior Parts.
We have more 20V and 16V parts on their way from Japan and they will be uploaded on the store soon. We also will be stocking 20V VVT solenoids in the US for reasonable prices – a first for a US based company. Normally the wait time is 4-6 weeks to get a new solenoid.
Blacktop Hydraulic Timing Belt Tensioner
Brand new AE111 Hydraulic Timing Belt Tensioner.
-Black top only
-Comes in Toyota packaging
-Ready to install
Due to the high compression ratio, Blacktop's are the only engines of the 4AG series that will have piston to valve contact if the belt slips or breaks. Slippage can occur if the hydraulic tensioner is has become weak or fails.
These tensioners are recommended to be replaced every other timing belt change but we like to replace them any time the belt is off for maintenance as it is cheap insurance.
20V Headgasket
Brand new factory Toyota Headgasket for 20V 4AGE.
-For Silvertop and Blacktop engines.
-1.4mm uncompressed height
-Approx 1.0mm compressed height after head is torqued.
-Great sealing properties with trusted Toyota reliability.
20V Intake Cam Seal
Brand new factory Toyota intake cam seal.
-For Blacktop and Silvertop
-Cheap insurance for a leak free rebuild
Install with a pea-sized amount of Permatex Grey around outside of seal, and the same amount of synthetic grease wiped around inside edge for best results.
16V 4AGE exhaust cam seals sourced from dealership or local parts store work for 20V exhaust cam as well!
20V Valve Cover Gasket
Brand new factory Toyota valve cover gasket.
-Combine with a dab of Permatex Grey at the corners to help ensure a leak-free install.
20V Timing Belt
Brand new factory Toyota 20V timing belt.
-Replace any time timing belt is removed.
-Comes with label in Japanese or English to keep track of timing belt maintenance.
Blacktop engines will have piston to valve contact if timing belt slips or fails. High compression pistons or high lift cams installed on Silvertop engines may result in piston to valve contact if timing belt slips or fails. Because of this, we only use factory Toyota timing belts when servicing 4AG's as risking valve train damage isn't worth the few bucks saved with an off-brand.
Please select if for Silvertop or Blacktop below.
4AGE Cam Cover Marker
Brand new factory Toyota cam cover marker.
-For 16V cam cover.
-Fits well on 20V Blacktop cam cover
We also have TRD shift knobs for sale
Please check out our webstore for pricing and email for more info
Link to our store:
http://www.battlegarage.bigcartel.com/c ... -20v-parts
Please like our Facebook page - our Facebook contacts will be the first to know about new promotions and new parts being developed!
http://www.facebook.com/pages/Battle-Ga ... 09?fref=ts
BOXER4BG_RS
Re: BATTLE GARAGE-RS 20v MAINTENANCE PARTS
Postby BOXER4BG_RS » Thu Feb 07, 2013 5:12 pm
Updated
BOXER4BG_RS
Re: BATTLE GARAGE-RS 20v, 16v, TRD, and Interior Parts
Postby BOXER4BG_RS » Mon Feb 11, 2013 10:29 am
Just got a shipment of parts from Japan please PM me parts that you need
BattleGarage_RS
Postby BattleGarage_RS » Wed Feb 13, 2013 9:37 am
We have some experience working with GZE's as well. Let us know if you are after something for a USDM or JDM GZE engine.
We actively stock most Toyota parts you see on our store, including some that normally require at 4-6 week wait!
BT OIl Pump
BT Water Pump
20V Cap
20V Rotor
Last edited by BattleGarage_RS on Thu Apr 25, 2013 4:18 pm, edited 1 time in total.
BattleGarage_RS
Postby BattleGarage_RS » Sun Feb 24, 2013 12:11 pm
Bump
BattleGarage_RS
Postby BattleGarage_RS » Mon Feb 25, 2013 10:07 am
More items added to our stock, and more are coming.
Recently added to local stock:
AE86 BNIB throttle cable
20V VVT Solenoid
AE86 center console lids
AE86 TRD leather shift knob - round type.
20V Distributor O-ring
20V Spark plug gaskets/grommets
Last edited by BattleGarage_RS on Thu Apr 25, 2013 4:22 pm, edited 3 times in total.
BattleGarage_RS
Postby BattleGarage_RS » Tue Feb 26, 2013 5:53 pm
Toyota Silvertop and Blacktop tensioner pulleys (sealed bearings) coming into stock soon.
BattleGarage_RS
Postby BattleGarage_RS » Thu Feb 28, 2013 10:23 pm
More items added to local stock.
Zenki85
Postby Zenki85 » Thu Feb 28, 2013 10:31 pm
How much is throttle cable?
TEAM 'CLASSIC
A 'CLASSICALIFORNIACAR
BattleGarage_RS
Postby BattleGarage_RS » Fri Mar 01, 2013 8:22 am
Check here for pricing if you don't mind:
http://www.battlegarage.bigcartel.com/category/4age-20v-parts
CanDo7
Postby CanDo7 » Sat Mar 02, 2013 3:13 am
Got any 20v TPS's?
BattleGarage_RS
Postby BattleGarage_RS » Mon Mar 04, 2013 8:24 pm
We can order a 20V TPS for you but honestly I would just get one from a 1UZFE in the junk yard. It is supposed to be either the same part number, or at least be plug and play. Let me know if you still want me to order one for you.
BattleGarage_RS
Postby BattleGarage_RS » Wed Mar 06, 2013 11:35 am
Yep, looks like 1uzfe tps from the yard will work.
CanDo7
Postby CanDo7 » Sat Mar 09, 2013 1:53 am
Any year 1uzfe? A buddy of mine got one for me and it spins the wrong way. The 20v throttle spins clockwise and the TPS he got me spins counter clockwise.
BattleGarage_RS
Postby BattleGarage_RS » Sun Mar 17, 2013 10:08 am
To be honest I haven't tried it myself, this is just what I was told. I'd still be looking for a mid-90's Toyota TPS there must be one that is interchangeable...Toyota always shares sensors on cars from the same era.
BattleGarage_RS
Postby BattleGarage_RS » Wed Mar 20, 2013 2:45 pm
We will now be stocking 20V tensioner bearings too.
BattleGarage_RS
Postby BattleGarage_RS » Wed Mar 20, 2013 11:23 pm
VVT Solenoids and blacktop tensioners are out of stock. I will update when we have more in from Japan.
BattleGarage_RS
Postby BattleGarage_RS » Tue Mar 26, 2013 3:14 pm
Now carrying blacktop complete overhaul gasket kits - OEM Toyota
ronny
Postby ronny » Fri Mar 29, 2013 6:55 pm
bought all my blacktop overhaul stuff from alex and grant. big thank you.
Rays - Project Mu - TE37 club
BLUE MOON / CUSCO
AE86fightclub.com
PM me for Contact
BattleGarage_RS
Postby BattleGarage_RS » Sun Mar 31, 2013 2:34 pm
Thanks for the support man!
Your second order should all be in. Once it's checked in we will get it all mailed out. :D
BattleGarage_RS
Postby BattleGarage_RS » Mon Apr 08, 2013 5:28 pm
Now carrying 20V Oil pump, distributor caps and rotors!
BattleGarage_RS
Postby BattleGarage_RS » Wed Apr 17, 2013 8:25 pm
Blacktop Water pumps in stock!
We appreciate the orders so far and it has given us the confidence to keep more and more inventory in local stock $$$ for a fast turn around time.
Thank you all.
BattleGarage_RS
Postby BattleGarage_RS » Fri Apr 19, 2013 3:56 pm
Just a reminder, just about all of the OEM Toyota parts we have on our store we either have active local stock of, or more are on the way. We order many of these JDM only parts 4-6 weeks ahead of time and bring them in so you don't have to wait!
BattleGarage_RS
Postby BattleGarage_RS » Thu Apr 25, 2013 4:19 pm
Even more items have arrived into stock!
Thanks for you time.
BattleGarage_RS
Postby BattleGarage_RS » Thu May 02, 2013 4:15 pm
More parts in stock!
BattleGarage_RS
Postby BattleGarage_RS » Tue May 07, 2013 10:02 am
Thanks you everyone. We are putting in an order to keep more JDM only parts in stock - keeping things available and easy to access for the 4AG community.
BattleGarage_RS
Postby BattleGarage_RS » Mon May 13, 2013 11:53 am
Hydraulic tensioners are sold out...we will be getting more from overseas by this coming Monday.
VVT solenoids are back in stock!
Thanks everyone.
BattleGarage_RS
Postby BattleGarage_RS » Wed May 29, 2013 12:03 am
Hydraulic tensioners have sold out again, but we will have about 5 more coming in the next week.
Blacktop OIl pump soon to be back in stock!
Thank you everyone.
BattleGarage_RS
Postby BattleGarage_RS » Thu Jun 13, 2013 3:44 pm
Lots of blacktop tensioners in stock - both bearing and hydraulic.
Blacktop Oil pumps and water pumps also in stock.
Thanks!
BattleGarage_RS
Postby BattleGarage_RS » Wed Jun 19, 2013 12:43 pm
Up to the top.
Users browsing this forum: No registered users and 14 guests
