7 Rib Block + Crank, 42/20mm Rods, Previa Supercharger
Chubi
Postby Chubi » Thu Oct 17, 2013 3:14 pm
Located at work in Fullerton, can meet u somewhere in between there and Torrance where i live.
$120 OBO
4AGE Rods. 42mm/20mm ends - $OLD
SC14 Supercharger off a previa- $OLD
Chubi
Re: 7 Rib Block + Crank, 42/20mm Rods, Previa Supercharger
Postby Chubi » Mon Oct 21, 2013 5:07 pm
bumppppp
Chubi
Postby Chubi » Mon Oct 28, 2013 3:54 pm
up up upppp
Chubi
Postby Chubi » Sat Nov 02, 2013 6:29 pm
to the topppppp
phanist
Postby phanist » Tue Nov 05, 2013 1:47 pm
is this 7rib block the same as the 20v BT block?
ga_goosh
Postby ga_goosh » Thu Nov 07, 2013 9:37 am
Chubi,
what condition is the crank? was there any spun bearings? and will you sell just the crank?
phanist wrote:is this 7rib block the same as the 20v BT block?
this block is a 16v block the 20v blocks have the cut out like the 4af blocks but you can build a 20v with this block. you will just need a 16v pan.
I <3 my AE86
4AG Manual
AE86 FSM
Chubi
Postby Chubi » Fri Nov 08, 2013 5:22 pm
ga_goosh wrote:Chubi,
the crank is in good, useable condition, crank spins no problems, bearings are not spun but i recommend replacing them haha
phanist
Postby phanist » Sat Nov 09, 2013 4:03 pm
u mean if some one have a 20v head they can use this block and make a full 20v?
Chubi
Postby Chubi » Sun Nov 17, 2013 10:46 pm
bumppp
sgonzalez
Postby sgonzalez » Fri Nov 22, 2013 6:53 am
Chubi wrote:bumppp
Hello Pal Interested on the Rods I sent you an IM
Chubi
Postby Chubi » Sat Nov 23, 2013 1:31 am
sgonzalez wrote:
Chubi wrote:bumppp
got no pm...
pm'd u lol
Chubi
Postby Chubi » Mon Nov 25, 2013 2:31 pm
SC14 Sold bump
Chubi
Postby Chubi » Fri Dec 06, 2013 4:47 pm
bump it uppppp
comhosa
Postby comhosa » Sat Dec 21, 2013 12:21 am
check your pm
Chubi
Postby Chubi » Sat Jan 04, 2014 11:10 am
Rods sold, bump upp
tmburt
Postby tmburt » Sun Jan 05, 2014 5:37 pm
How much for the block and crank shipped to Louisville, KY USA?
Chubi
Postby Chubi » Mon Feb 10, 2014 7:41 pm
not shipping a block lol, bump
83norcarolla
Postby 83norcarolla » Thu Feb 20, 2014 6:00 pm
yo im down to pick up the block- text me 818 ninenine3 two6seven3 ---ray
