tourqe spec. for ST 20v head
javiakakinghoopty
Postby javiakakinghoopty » Mon Aug 05, 2013 3:49 am
Just replacing head gasket
jdm86gtz
Re: tourqe spec. for ST 20v head
Postby jdm86gtz » Mon Aug 05, 2013 6:31 am
Same as a 16v head: 29Nm, turn 90 degrees, turn 90 degrees.
Tighten every bolt in each stage before moving to the next stage, starting in the middle of the head and working out in an X pattern.
Postby yoshimitsuspeed » Mon Aug 05, 2013 7:51 am
It should be noted that method only applies to a setup with stock headgasket and stock head bolts. If either of those change so must the tightening method.
