question for mishimoto an koyo radiator owners!
El_Burro
Postby El_Burro » Wed Oct 16, 2013 11:06 am
Hi, my original radiator is busted and I want to buy an aluminum 2 row since florida heat + running the a/c seem to put a big load on the cooling system at idle.
I'm really considering either a mishimoto or koyo aluminum 2 row radiator, But I dont want to run higher PSI caps,
My question: Is it possible to use the OEM cap on either of these radiators?
Thanks,
J.A
Re: question for mishimoto an koyo radiator owners!
Postby yoshimitsuspeed » Wed Oct 16, 2013 1:04 pm
The Mishimoto won't but it takes a standard WRX cap so you could get any standard pressure cap for any WRX and it would work.
http://matrixgarage.com/products/mishim ... a1983-1987
I am looking into the Koyo's right now.
Postby Deuce Cam » Wed Oct 16, 2013 1:15 pm
Yes. The ae86 specific Koyo and Mishimoto radiators utilize the same style/size radiator cap as oem. I used an oem replacement cap on my Mishimoto radiator because the MIshimoto cap is ugly as sin.
jdm86gtz
Postby jdm86gtz » Wed Oct 16, 2013 2:09 pm
I have a TRD oem replacement cap on my Koyo
Postby yoshimitsuspeed » Wed Oct 16, 2013 2:43 pm
Interesting to hear on the Mishimoto caps.
It came straight from Mishimoto that the stock cap wouldn't work.
Postby Deuce Cam » Wed Oct 16, 2013 3:00 pm
^There have been a few versions over the years I believe. Perhaps the earlier ones didn't have the oem style filler neck.
Mishimoto
Postby Mishimoto » Thu Oct 17, 2013 9:51 am
The ae86 cap may work, but we have never tested for fitment. We have confirmed that a cap from an 02-07 WRX should fit without any problems. :)
PT86
Postby PT86 » Thu Oct 17, 2013 9:39 pm
Yes the OEM Toyota cap will work, I'm using a Cusco cap on mine, fits great.
El_Burro
Postby El_Burro » Sun Oct 20, 2013 5:19 pm
thank you all for the replies. Ended up buying a Koyo. Glad to hear the stock cap fits. No need to run a higher pressure cap on a stock car I guess.
Thank you .
Postby yoshimitsuspeed » Sun Oct 20, 2013 5:35 pm
Glad I took the time to Call Mishimoto and research this for you so you could go buy your rad somewhere else.
allencr
Postby allencr » Sun Oct 20, 2013 5:54 pm
Let no good deed go unpunished.
Y. Very few if any talented & honest & helpful people make a good living in the auto world IMO.
