Projekt 8086
808AE86inAZ
Projekt 8086
Postby 808AE86inAZ » Sat Aug 31, 2013 1:28 pm
Sup C4AG, I'm Monte, and I picked up this after moving to PHX from Hawaii...
I'll keep it short since most of u like pix better than text, unfortunately half da pix will get cut in half but wtfe. So it was all stock, tow truck backed into the RF fender n headlight which I swapped out 1st, but it already came with THIS!!!
Supposedly a JDM AE92 redtop small port hi comp, identified by...
And the oil drain back...
And the chop n swap intake manifold...
Sooo... I've had it for 8yrs, got it running but could never get it to idle. It would jus surge from 1300-1800rpm unless u were on the throttle. Compression tests - pass, 190-195psi front to back. Leak down tests - pass. Removed IAC to clean n reseal, no change. Pulled countless vacuums on the cooling sys to remove any trapped air, uh uh. A ton of other techs over the years, have tried their hand at it, fail. Took it to Akina Motorsports waaaay back when, fail... I went back thru everything I could think of, threw a few parts at it, fail. Met owner of another local import shop, dropped it off at Suspicious Garage, fail. So I came up with this idea...
Twin Weber DCOE 45's, linkage, and a big port carb manifold but being that she's got a small port, I needed one of these...
Tried using stock pump and return style fpr...
Fail. So I picked up an in-tank Carter HVLP and a Holley LP dead head FPR
MSD tach asapter, MSD 6AL2, stripped down n modified GTS (I'm an idiot i kno..) harness, wired to a new bluetop dizzy and came up with this 8)
Scored some 15x8 +0 and 15x9 +0 from 2tone86...
Threw on some Espilir's I had and came up with this...
The rears were literally sitting on the virgin fender lips, so after snapping these pix I threw the stock rear springs back on...
Still got a ways to go and tons of things to buy but she's getting there.
Goals: Clean, track capable street car, like these...
Current list of **** I still want (and ordering)is huge but includes:
- rotors, pads, front bearings, races, n seals
- new rad, fans, n T3 shroud
- Mocal oil cooler, lines, n sandwich plate
- Innovative wideband
- arms, links, bushings, bars, coilovers (want Greddy's REALLY bad but probly going T3 complete suspension front n rear)
- more street tires, Diamonds wit track stickies
- get a/c lines redone, condenser redone, and a new comp n accumulator
- tint n interior n paint last
Blah blah blah, that's all I got, here's how she runs right now...
http://youtu.be/wyvd4IZQKcY
shoots den
Step 1: Remove head from ass.
ay fu@k u ok, u don't kno me bra
http://www.eight08.net/features.html
HingaSPL
Re: Projekt 8086 (PIC HEAVY!!!)
Postby HingaSPL » Sat Aug 31, 2013 3:52 pm
Nice start. Is that cruise control over by the brake master? Never seen one of those set-ups.
ajadorifter
Postby ajadorifter » Mon Sep 02, 2013 10:15 am
Yeah Everyone Usually Just Rips Them Out
BlueDeathTrap
Postby BlueDeathTrap » Mon Sep 09, 2013 9:37 am
HAH! I recognize that carb setup anywhere! That's my old setup! Wow, got shipped halfway across the country, but yeah, definitely looks like my old rig. How's she treating you?
808AE86inAZ
Re: Projekt 8086
Postby 808AE86inAZ » Thu Mar 20, 2014 8:14 pm
PHOTO DUMP!!!
TorParts shtuff
88Rotors shtuff
Innovative Wideband
(left to right) Autometer Elite eng oil pres, eng coolant temp, and Innovative Wideband
Greddy oil cooler adapter
B&M cooler
HKS Sport
Pacesetter header
Rad n fans
T3 shtuff
Front coilovers and ARP's
Rear susp and ARP's
Eng bay as it is now
YOTAHOLIC808
Re: Projekt 8086
Postby YOTAHOLIC808 » Sat Mar 22, 2014 8:49 pm
Dope! Much love for the carbs!
@_yotaholic
ae86crk
Re: Projekt 8086
Postby ae86crk » Tue Mar 25, 2014 10:46 am
how much was your header? nice too see another 86 here in phx dont see many guys on the forum
bboys34
Re: Projekt 8086
Postby bboys34 » Thu Mar 27, 2014 9:33 am
Nice build! I miss my 44 mikunis. Anyways just wondering where I can get those heat shield by the booster? Any info would be greatly appreciated thanks.
yellowsnow4free
Re: Projekt 8086
Postby yellowsnow4free » Thu Mar 27, 2014 10:59 am
bboys34 wrote:Nice build! I miss my 44 mikunis. Anyways just wondering where I can get those heat shield by the booster? Any info would be greatly appreciated thanks.
I'm not sure what 808AE86inAZ used, but I know people use the brake booster heat shield from a TE72.
808AE86inAZ
Re: Projekt 8086
Postby 808AE86inAZ » Thu Mar 27, 2014 8:24 pm
ae86crk wrote:how much was your header? nice too see another 86 here in phx dont see many guys on the forum
There's a few AZToyota.org guys on here, toywagon (no 86's but a Yota hoarder for sure), duece cam, flowisode zero, sideways, and not to forget haymaker. The header was $180 from eBay seller Horsepower Freaks. Even tho Pace Setter is here in AZ, it was waaaay cheaper of eGay.
Hey thx! Flowisode Zero sold me that booster heat shield for like 10 bucks. I dunno what it's from originally tho. Bought it, cleaned it up and hit it with some aluminized high temp paint. I got a dizzy heat shield from him too but it don't fit cuz it's for a FWD/MR2 style dizzy.
808AE86inAZ
Re: Projekt 8086
Postby 808AE86inAZ » Wed Apr 02, 2014 5:58 pm
UPDATE:
- pulled engine and fan harnesses out again and redid a few things
- tuned ECT gauge to runs fans properly
- set ride height with intended wheels and tires
- installed strut tower bar
- cracked windshield while installing dash mat
- tuned and retuned carbs (AFR's ~12.5 - 13.5ish)
- tuned ignition timing as best as I know how for now (12deg BTDC 0-1500rpm curving to 37deg BTDC from 3500 - redline.)
- put 20mi on er today after work, recheck for leaks - pass.
It's funny cuz all this time, I've either been under the hood or under the car but never behind the wheel. Now I get to find out all the other shyt that's wrong with it...
- need a headlight switch, as my interior and exterior lighting work intermittently
- annoying ass buzzing from passenger footwell, seems to match eng rpm (suspect MSD tach adapter)
- obviously need a new windshield now
- everything I touch crumbles to dust i.e. top seatbelt trim things, door cups, seats, etc
808AE86inAZ
Re: Projekt 8086
Postby 808AE86inAZ » Thu Apr 03, 2014 5:36 pm
Did another shake down run with er today. Not bad, carbs need more tuning. Either that or more ignition timing tuning. O Snap!
Liking the desert patina
Driveway paparazzi
I hate how C4AG cuts the pix in half... Anyone know how to resize um???
Users browsing this forum: Bing [Bot] and 9 guests
