4AG 20V ST, GZ crank.. thoughts?
Gabriel82
Postby Gabriel82 » Thu Aug 29, 2013 10:37 am
Would it work? What advantages? Would it work with a 20v head 7A block as well?
ga_goosh
Re: 4AG 20V ST, GZ crank.. thoughts?
Postby ga_goosh » Thu Aug 29, 2013 1:59 pm
the silver top crank and the gze crank are the same thing. they both have the same part numbers. if you use these in a 7a block you will loose compression due to a taller block deck height. and the 7a rods have a different journal size. unless you boost this motor (and maybe not even then) to all hell or get custom rods it wont be worth the time.
I <3 my AE86
4AG Manual
AE86 FSM
