20V BT water pipe question
bwh13
Postby bwh13 » Thu Jun 20, 2013 7:17 pm
On the back side of the head, connecting the water pump outlet to the head, there is a cast water passage or something similar. Are there gaskets that go between that piece and the waterpump and head? If so are there replacements available?
Mine drips every once in a while and I'd like to replace them.
gotzoom?
Re: 20V BT water pipe question
Postby gotzoom? » Fri Jun 21, 2013 5:15 pm
RTV and you're done. You can also buy rolls of gasket material from most autoparts stores and cut your own.
bwh13
Postby bwh13 » Fri Jun 28, 2013 4:34 pm
OK thanks
morgan
Postby morgan » Sat Jun 29, 2013 11:14 am
Buy the Toyota oil pan rtv, I have a spare bnib tube if interested. PM me if you want pics or p/n
My turd of an 86
20v swapped 86 write-up
