16V TRD Headgasket part numbers?
overspool
Postby overspool » Tue Apr 30, 2013 1:21 pm
So, I have been scowering the internet for the part numbers for the TRD head gaskets. I found the first one...
.8MM TRD Gasket- PTR04-17900-03 or... 00643-11115-000
But, I can't seem to find the part number for the elusive .5mm head gasket for the 16v. They are easily found for the 20v engines. Help me out guys. I'm tearing apart my motor again, and I figure I'll do a little bit of fixing up while I'm in there.
ga_goosh
Re: 16V TRD Headgasket part numbers?
Postby ga_goosh » Fri May 03, 2013 5:09 am
here is a good trd part number list
P# Cylinder Head Gasket, Metal, .8 11115-AE814
http://www.86garage.com/forums/viewtopic.php?f=17&t=2042
here is another TRD refference
http://www.hachiroku.net/forums/showthread.php?t=12944
the .5mm head gasket is not a TRD part it is a standard toyota gasket from a 7afe engine the car it came in is a 95 toyota celica and will work on your 4ag
P#11115-16121
I <3 my AE86
4AG Manual
AE86 FSM
overspool
Postby overspool » Sat May 04, 2013 3:33 pm
AH so that's why I couldn't find anything. Thanks dood!
Also, that first part number you provided (for the TRD .8mm) is actually a "superseded" number. It no longer pulls up anything in the Toyota system. If you search for that part number on teh interwebz, it will pull up the Initial D fan boi prices ($80+) most of the time, whereas with the part numbers I posted you can get it for like $42+ shipping :)
drift0nedge
Postby drift0nedge » Sat May 11, 2013 2:35 pm
overspool wrote:AH so that's why I couldn't find anything. Thanks dood!
any links by any chance?
8Ton
Postby 8Ton » Sun May 12, 2013 3:53 am
drift0nedge wrote:any links by any chance?
Its not a painting from the 1500's. You can find it on your own.
overspool
Postby overspool » Sun May 12, 2013 9:12 am
Postby oldeskewltoy » Fri May 17, 2013 8:39 am
P#11115-16121
I know one part of this is not accurate (no .5mm TRD gasket), and I believe the thickness you stated for the 7AFE is also wrong. I have the understanding that the 7AFE gasket is .7mm thick.
The TRD .5mm gasket is 11115-AE824, list price on both the .8, and the .5 are 6000 yen, or about $59.00
ga_goosh
Postby ga_goosh » Fri May 17, 2013 7:34 pm
oldeskewltoy wrote:
P#11115-16121
that could be true i dont know for sure. i do know the 7afe is a mls and it is a thin gasket and i think it has 3 layers? not too sure. i was under the impression it was .5 but iv been wrong before and i will probably be wrong again lol maybe with the 3 gaskets put together are .7 thick? i read somewhere that it is like .4 or .5 per layer? again not too sure I did find this description of the 7afe gasket listed at .4mm http://cn.oemol.com/oem/en_oem_detail/43179/11115-16121/TOYOTA_CylinderGasket.html
I found these part numbers but they might be old numbers
http://www.trdparts.jp/english/parts_engine-4a-g16.html
16v
11115-AE824 (t=0.5)
16v
11115-AE814 (t=0.8 )
apparently there is also a TRD 1.1 mm head gasket too but its discontinued
16v carbon gasket
11115-AE802 (t=1.1)
I <3 my AE86
4AG Manual
AE86 FSM
Users browsing this forum: No registered users and 13 guests
