https://technotoytuning.com/toyota/ae86/tokico-hts-full-stroke-shockst-ae86-corolla
If I was to purchase these shocks. Would it work with TRD Race Springs or Swift Non Coilover for the AE86 without shortening the strut assembly?
Full Stroke HTS AE86
Formerly known as seanperia
Re: Full Stroke HTS AE86
Yes. They are physically the same as the short stroke version.
with a non-shortened casing would it be an issue with a lowered height and the desired function of the TRD springs?
No, as long as you use the included spacer that comes with it. It should keep the TRD springs in place during rebound.
What he said
I'm running HTS112 and they will NOT hold TRD linear rate springs from coming loose, you need the HTS102 to hold the TRD linear springs.
I'm using the HTS112 in my car and they need some special fitting to keep my almost full height springs from coming loose
http://www.hachiroku.net/forums/showpos ... tcount=212
I stand corrected. I am also using HTS112 with intrax progressive springs. After looking at your hachiroku post, my HTS112 came with the regular spacer size that came with the HTS102, a 2~3 mm washer under the gland nut. I did not need to create a top spacer and there is no play after installation. The intrax springs once installed have a good amount of preload.
oldeskewltoy wrote:I'm running HTS112 and they will NOT hold TRD linear rate springs from coming loose, you need the HTS102 to hold the TRD linear springs.
What do you mean by using HTS 102 short stroke to hold linear springs?
YokoAE86 wrote:oldeskewltoy wrote:I'm running HTS112 and they will NOT hold TRD linear rate springs from coming loose, you need the HTS102 to hold the TRD linear springs.
the stronger TRD springs are less extended(shorter) when loose than an OEM spring. Because of this the HTS102 opens less then the 112, to hold shorter length springs
HTS102 listing on left, 112 listing on right - note the dimensional differences.
to Garage7RP... I had the same spacer... it was too long for my application, I had a friend cut it in half, and make an equal amount he cut off, for the top spacer
can this function with any lowering springs?
