OST Cylinder Head Porting Services
Postby oldeskewltoy » Thu Jan 10, 2013 12:34 pm
A quality port job can add power,and ECONOMY, even while retaining stock parts! Because casting imperfections are removed, not only are power gains likely, but more even airflow promotes even combustion, which promotes cleaner emissions. More airflow, more power... less throttle angle required to hold a speed... likelihood of better mileage (if you can resist the urge :D )
BIG EDIT - Since I ALWAYS recommend a minimum level of work, I decided that pricing should reflect that minimum amount of service. I've condensed the bowls, and seats, tapering the guides, deshrouding and balancing the chambers, and the exhaust port re-taper into the minimum service I'll offer.
$600 (minimum service) to do the 16 bowls/seats, taper the valve guides, deshroud and balancing chamber volume, exhaust port re-taper, and polishing.
$150 to blend the intake guide bosses and to re-taper port roof - largeport
$175 to blend intake guide bosses, blend port walls, and re-taper port roof - smallport
$125 adding intake side oil drain
$100 for machining of the heads surface
$80 for cam journal deburring and polishing, and overall deburring
$80 for hand lapped valves
$60 for re-assembly
$60 to set valve clearances - your supplied camshaft
Loynings valve jobs - a few hundred to a few thousand
I can be contacted via email oldeskewltoy@yahoo.com , or bump my thread :thumbsup: NOW ACCEPTING PAYPAL!
Some examples of my work
exhaust port work....
Image Image
Chamber deshrouding....
Intake port shaping....
Short radius shaping....
bowl shaping....
surface machining
my entire porting portfolio - http://s79.beta.photobucket.com/user/ol ... brary/MOmo
ronny
Re: OST Cylinder Head Porting Services
Postby ronny » Fri Jan 11, 2013 10:47 am
LEGIT!
Rays - Project Mu - TE37 club
BLUE MOON / CUSCO
AE86fightclub.com
PM me for Contact
Postby oldeskewltoy » Fri Jan 11, 2013 1:05 pm
ronny wrote:LEGIT!
When ever you are ready Ronny... ;)
I'll be happy to massage a cylinder head for you..... :twisted:
Here are a few of my previous builds - https://www.google.com/search?q=oldeske ... 96&bih=604
ga_goosh
Postby ga_goosh » Tue Jan 29, 2013 7:55 am
do you know what the average cost is to ship a head? im a bit interested in your service. thanks let me know
I <3 my AE86
4AG Manual
AE86 FSM
Postby oldeskewltoy » Tue Jan 29, 2013 10:01 am
ga_goosh wrote:do you know what the average cost is to ship a head? im a bit interested in your service. thanks let me know
from most areas in the USA... somewhere between $30 and $40. there is some cash to be saved by shipping USPS. Return freight is usually a bit more($10+) because I typically insure it for $800-$1000.
Postby oldeskewltoy » Tue Jan 29, 2013 10:14 am
oldeskewltoy wrote:Short radius shaping....
Above is Port #4... here are the other 3 ports....... :shock:
Port 3
Port 2
Port 1
Hmmm, I think I heard you..., "What does an unported short radius look like??" Well I don't have a photo of those (ports above) prior to work, but here is another head showing the short radius before...
and after.......
Interested??? Send me an email - oldeskewltoy@yahoo.com
ga_goosh
Postby ga_goosh » Tue Jan 29, 2013 10:49 am
cool thanks for that info your work is VERY top notch :mrgreen:
I <3 my AE86
4AG Manual
AE86 FSM
Postby oldeskewltoy » Tue Feb 12, 2013 11:49 am
Bump...
checking/verifying chamber volume.....
A bit of custom work to provide adequate clearance for those BIG cams....
As well as doing the detail work that others don't......
Before (all except bottom left)
After........
It just doesn't get any simpler - view the exhaust port on the left as it goes from beastly to beauty........
Just send me an email ;) oldeskewltoy@yahoo.com link > oldeskewltoy@yahoo.com
Postby oldeskewltoy » Tue Feb 19, 2013 2:53 pm
bump...
VERY shortly I'll be offering flowbench services. I have not as of yet figured out how much I'll be charging. I also will not be offering this until I feel I can guarantee my #s.
To do this I've recently acquired some new equipment....
and so I KNOW I'm accurate with setting valve lift...
I've also had quite a few people help "train" me on my own equipment :lol:
the math involved in the flowbench makes my brain hurt :oops: ... so I've had a few people help dumb the theories down for me to simple actions(keystrokes) to operate "the tool" = flowbench
One service I'm planning to add to a minimum service.... is to show on a flowbench spread sheet, the progress of one cylinder from dirty/cruddy/old, to cleaned up original casting, to fully ported and ready to deliver. :D
I also plan on doing full port matching. This will be based on an hourly rate I'll set in the future.
Now TRUE port matching has nothing to do with hogging out the hole to fit the gasket...
What TRUE port matching is.... has EVERYTHING to do with making sure EACH PORT flows the same @ each lift point so that each cylinder get an IDENTICAL fuel/air charge so ALL cylinders are making the same power.
:D
Postby oldeskewltoy » Sun Feb 24, 2013 2:17 pm
from another forum wrote:
Sorry for the hijack, But is there a post somewhere with before&after flow numbers, or a percentage if you don't want give up the numbers? d:)b
I haven't taken look at much of your stuff, kinda gave up after too many polished ex port pics.
Why yes... I DO have PROOF of what I can do......
the little red arrows are pointing to 7.1mm lift, or cams from 1988+ 4AGE engines
the blue arrows are 7.5mm lift from the earlier pre 1988 4AGE engines
As the arrows show even with stock cams, my port work improves flow. Btw, those numbers were back in 2009, my exhaust port work has improved since then. :twisted:
Postby oldeskewltoy » Mon Jun 03, 2013 5:38 pm
Not just 4AG..... currently working on a 7MG head... OST-022 - viewtopic.php?f=12&t=4927
Checking the flow on #5
:mrgreen:
ssspacely
Postby ssspacely » Thu Jan 09, 2014 9:55 pm
what is your turn around time? I am interested in upgrading to mild cams as well. thanks.
Postby oldeskewltoy » Sat Jan 11, 2014 9:45 pm
ssspacely wrote:what is your turn around time? I am interested in upgrading to mild cams as well. thanks.
typical turn around for my work is about 2 weeks, add in a Loyning 3 angle and add a week.
best to send me an email to oldeskewltoy@yahoo.com
sekang0
Postby sekang0 » Tue Mar 04, 2014 12:13 am
Might be a long shot but wanted to see if you have a spare smallport head you could sell to me? I'd also need it ported too so all those charges for services would be added on of course. Thanks!
'85 GT-S project since 2010
Postby oldeskewltoy » Tue Mar 04, 2014 8:29 am
sekang0 wrote:Might be a long shot but wanted to see if you have a spare smallport head you could sell to me? I'd also need it ported too so all those charges for services would be added on of course. Thanks!
don't have one on hand now... but I can get a hold of one in 3 to 4 days... send me an email to oldeskewltoy@yahoo.com
As to what I've been doing recently..... :D I'm porting a head from a Mazda(Ford) 2.2 liter turbo. A few pics for you from that job....
exhaust work...
Chamber deshrouding
Intake bowls...
short radius, and port roof...
Stay tuned.... rumors of a certain 6 have come to light :shock:
sekang0
Postby sekang0 » Fri Mar 07, 2014 12:21 am
Emailed you
Postby oldeskewltoy » Sat Mar 15, 2014 3:35 pm
oldeskewltoy wrote:
exhaust work...
:mrgreen:
Postby oldeskewltoy » Mon Mar 24, 2014 9:20 am
Do to Uncle's Sam, and Kitzhaber requirement for taxes... beginning with OST-027 my prices will rise... (see first post)
I'm sorry... but I have kept things pretty steady for the past 4 years....
And now a distraction - Some recent work
Reuterskiold
Postby Reuterskiold » Sun Jul 06, 2014 3:59 pm
Hi this is slightly unrelated but I figured since 4age head work is what you do, you might know these numbers off the top of your head
hello all, I'm in the middle of rebuilding a Small port, it's a mild build, balanced bottom end, .020 over, etc........ I am sooooo close to having it back in my hands but my machinist just needs a couple specs before I can get it. so i was wondering if anyone would know off hand some numbers...
WHAT IS THE OE HEAD GASKET THICKNESS COMPRESSED?
OE PISTON TO DECK CLEARANCE?
OE VALVE TO PISTON CLEARANCE?
thank you for your help
Postby oldeskewltoy » Sun Jul 06, 2014 6:35 pm
Reuterskiold wrote:Hi this is slightly unrelated but I figured since 4age head work is what you do, you might know these numbers off the top of your head
1.2mm is the OEM gasket compressed thickness.
OE Piston to deck is unreliable... I've measured USED engines I've ASSUMED are original @ .002" to .003"
The OE valve to piston is somewhere in excess of 7.5mm because the engine is none interference and so with stock cams(7.5mm lift), the pistons do not hit if you break a belt.
Postby oldeskewltoy » Fri Mar 06, 2015 10:41 am
Been way to long since an update.....
getting those cam caps deburred, and buffed
getting the intake bowls just right to optimize flow
and we can't forget the exhaust work....
Postby oldeskewltoy » Tue Sep 29, 2015 5:58 pm
Some recent 20V work..........
exhaust side....
and a bit from the intake side... with a bit of negative effects to better highlight the work performed
Send me an email if you are interested in port work - oldeskewltoy@yahoo.com
Postby oldeskewltoy » Tue Nov 10, 2015 10:29 am
New service - adding an intake side oil drain - $125.00
Advantages: 1) minimizes some oil blowby (that happening on long left hand sweepers), 2) helps oil drainage from the head
Postby oldeskewltoy » Thu Sep 01, 2016 3:21 pm
Not all my work is on 4AGE heads...
SR20VE
BP-VE (Miata VVT)
Postby oldeskewltoy » Fri Dec 16, 2016 3:20 pm
RandalllFer wrote:does anyone know of any good cylinder head porting places in north qld, with flow bench and all the proper gear to do it?
I do ship heads world wide........ oldeskewltoy@yahoo.com
Postby oldeskewltoy » Sat Dec 02, 2017 1:54 pm
Still running SC12...... and OEM manifold :o
I do ship heads worldwide.... ;) oldeskewltoy@yahoo.com
Postby oldeskewltoy » Wed Dec 20, 2017 12:06 pm
azndrifter50
Postby azndrifter50 » Tue Aug 07, 2018 9:36 pm
Whats the turn around for a stock blue top ported and polish and angle job?
Location is los angeles.
Thanks,
Brian
Ae86 Ultimate
Master Mechanic and Master of the Custodial Arts
Los Angeles, CA
Postby oldeskewltoy » Wed Aug 08, 2018 8:59 am
azndrifter50 wrote:Whats the turn around for a stock blue top ported and polish and angle job?
it depends.... right now, it would be about 8-10 weeks ( a few jobs lined up) When I'm slow, 4-6 weeks.
send me an email if you'd like to discuss it further..... oldeskewltoy@yahoo.com
azndrifter50
Postby azndrifter50 » Sat Aug 11, 2018 7:01 pm
Email Sent!
Thanks,
Brian
Ae86 Ultimate
Los Angeles, CA
