HKS 5AGE stroker crank (40mm rod journal) w/ Molnar 40/20 rods
Postby oldeskewltoy » Tue Feb 19, 2019 8:52 am
You get what you see - HKS stroker crankshaft, and a set of 40/20 Molnar connecting rods to fit the 40 mm rod journal HKS crankshaft. Crank has been checked carefully - magged, and checked for straight.
email me, respond to this post, send me pm.
Price is $2100.00 OBO
aemo86
Re: HKS 5AGE stroker crank (40mm rod journal) w/ Molnar 40/20 rods
Postby aemo86 » Tue Feb 19, 2019 6:56 pm
can thiis fit for HH red top block?custom pistons?
UNLIMITED 86
Postby UNLIMITED 86 » Tue Feb 19, 2019 9:08 pm
I have a set of the origial HKS pistons for this crank that I have no plans to use, if that piques anyone's interest...
IG: unltd_86
Postby oldeskewltoy » Tue Feb 19, 2019 9:44 pm
aemo86 wrote:can thiis fit for HH red top block?custom pistons?
Yes - if you are asking if this will fit a smallport 4A block
all "A" cranks fit all "A" blocks as the main bearings are the same.
Postby oldeskewltoy » Wed Feb 20, 2019 7:24 am
kinda rushed to answer.... a 7A crank will fit the 4A journals, but it is too big to rotate - so you can't really fit "any" "A" crank into any "A" block. The HKS stroker crank does need some block modifications to work in a 4A block. the inside base of the cylinder walls @ the bottom may need to be ground down so the rods can pass - not uncommon when fitting an 83mm stroker crank into a 4A block
Postby oldeskewltoy » Tue Mar 05, 2019 9:51 am
Bump............ or best offer
sirdeuce
Postby sirdeuce » Tue Mar 05, 2019 3:48 pm
You couldn't take my offer. Work is real slow, offer would be real low.
One shot, one kill.
Postby oldeskewltoy » Sat Mar 30, 2019 7:44 pm
Bump $1800.....
Postby oldeskewltoy » Wed Jul 17, 2019 11:42 am
bump... still available...
also available w/o the rods for $1400
Postby oldeskewltoy » Fri Sep 13, 2019 4:47 pm
bump......
Driverone
Postby Driverone » Thu Jan 02, 2020 3:51 pm
800? and did you ship international
Postby oldeskewltoy » Thu Jan 02, 2020 7:28 pm
Driverone wrote:800? and did you ship international
too cheap... I do ship internationally at your expense
Driverone
Postby Driverone » Fri Jan 03, 2020 4:16 am
For some reason i cant pm you. For how much you would let it go?
Postby oldeskewltoy » Sun Jan 12, 2020 11:39 am
Driverone wrote:For some reason i cant pm you. For how much you would let it go?
check your messages....
Driverone
Postby Driverone » Sun Jan 12, 2020 2:46 pm
I figured out that i cant pm you because im not to active here sry. Probably both.
Postby oldeskewltoy » Mon Jan 13, 2020 11:12 am
Driverone wrote:I figured out that i cant pm you because im not to active here sry. Probably both.
send me an email oldeskewltoy @ yahoo
Driverone
Postby Driverone » Tue Jan 14, 2020 11:01 am
Sry. Something happend in the familie. And i cant afford it anymore at the moment.
