AE86 4A-GE 16v, 20v, F20c, MA46 and more parts!
souldrift86
Postby souldrift86 » Sat Feb 24, 2018 12:15 pm
- Small items are priced as shipped to the continental U.S.
- Large items will require a quote or identified as pick-up only.
- DM me for PayPal info (send as gift or help pay fee), questions, or additional pics.
Instagram: ssgt_ackers
text me 530 949 72three0
- I can ship small items during the week. Large items will be quoted and shipped over the weekend.
**Sacramento, CA 95833**
- Pick-up preferred.
4A-GE 16v GT-S
- 4A-GE 16v GT-S oil pan baffle - $50 shipped
SOLD! - 4A-GE 16v GT-S throttle body - $50 shipped
SOLD! - 4A-GE 16v GT-S TVIS plate - $20 shipped
SOLD! - 4A-GE 16v GT-S spark plug cover - $20 shipped
SOLD! - 4A-GE 16v GT-S fuel filter w/ bracket and soft line (hard line removed after pic). 5 mins of use – Like new. - $20 shipped
- 4A-GE 16v GT-S cam cover rubber gasket - $15 shipped
- 4A-GE 16v GT-S fuel rail - $30 shipped
- 4A-GE 16v GT-S bluetop injectors, 23250-34030, 2.4 ohm, 210cc - $50 shipped
- 4A-GE 16v GT-S cam backing plate $50 shipped
SOLD! - 4A-GE 16v GT-S IACV - $55 shipped
- 4A-GE 16v GT-S water pump $75 shipped
SOLD! - 4A-GE 16v GT-S AFM setup - $200 shipped
- 4A-GE 16v GT-S 8.84-5.85 US, 89661-12090, 175600-0011, ECU - $75 shipped
- 4A-GE 16v GT-S bottom radiator hose - $15 shipped
SOLD! - 4A-GE 16v GT-S T50 OEM shifter - $70 shipped
- 4A-GE 16v GT-S shift knob - $35 shipped
- 4A-GE 16v GT-S T50 driveshaft - $160 (requires shipping quote)
AE86 GT-S
- AE86 GT-S OEM 4-links - $90 shipped
- AE86 GT-S rear shock dust covers - $15 shipped
- AE86 GT-S spring cushions - $25 shipped
- AE86 GT-S crossmember - $150 (requires shipping quote)
- AE86 GT-S crossmember bolts - $30 shipped
SOLD! - AE86 GT-S front fender liners - $60 shipped
- AE86 GT-S hatch tail lights. One tail light is painted with Super Autobacs smoked paint - $140 shipped
4A-GE 16v AW11
- 4A-GE 16v AW11 (88-92) redtop largeport fuel rail, 250cc green injectors, pulsation damper, and FPR - $110 shipped
- 4A-GE 16v AW11 (88-92) redtop largeport cam covers - $80 shipped
- 4A-GE 16v AW11 (88-92) redtop largeport TVIS plate - $20 shipped
- 4A-GE 16v AW11 (88-92) redtop largeport waterline piping - $40 shipped
- 4A-GE 16v AW11 (88-92) redtop largeport ECU, 89661-17020, 175600-0040, M/T, 85-85 US - $75 shipped
- 4A-GE 16v AW11 (88-92) redtop largeport distributor cover - $15 shipped
* Tried to keep it together with black bumper bondo. The repaired side is hidden when covering the distributor.
4A-GE 16v
- 4A-GE 16v Magnecor R-100 Racing ignition cables 10mm silicone. - $85 shipped
- 4A-GE 16v/20v heavy-duty sprung pressure plate - from a shop in Vista. - $90 shipped
- 4A-GE 16v short ram air intake w/ AEM dry flow filter (used on JDM MAP setup) - $40 shipped
*How it looked fitted...Image
- 4A-GE 16v 7mm "Suppression Cable" ignition cables - $20 shipped
- 4A-GE 16v EGR Vacuum Modulator, vacuum switch valve, ECT sensor, CT sensor, and water line housing - $50 shipped
4A-GE 20v
- 4A-GE Blacktop 20v oil dipstick - $25 shipped
- 4A-GE Blacktop 20v water pump - $75 shipped
- 4A-GE Blacktop 20v engine oil pump screen pick-up tube - $30 shipped
- 4A-GE Blacktop 20v FWD heat shield - $15 shipped
SOLD! - 4A-GE Blacktop 20v OEM clutch, flywheel, and pressure plate - $150 shipped
- 4A-GE Blacktop 20v OEM trumpets x6 - $30 shipped / $8 each shipped
- 4A-GE Blacktop 20v intake camshaft - $150 shipped
- 4A-GE Blacktop 20v VVT intake pulley - $250 shipped
- 4A-GE Blacktop 20v exhaust pulley - $40 shipped
- 4A-GE Blacktop 20v exhaust camshaft - $150 shipped
- 4A-GE Blacktop 20v distributor - $80 shipped
- 4A-GE Blacktop 20v water outlet pipe - $20 shipped
- 4A-GE Blacktop 20v water inlet housing - $30 shipped
- 4A-GE Blacktop 20v No. 4 timing belt cover plate - $20 shipped
- 4A-GE Blacktop 20v No. 5 camshaft bearing cap - $20 shipped
- 4A-GE Blacktop 20v ISCV - $125 shipped
- 4A-GE Blacktop 20v custom airbox RWD- $120 shipped
AE86
- AE86 stainless steel braided brake lines - $60 shipped
- AE86 TRD oil cap - $25 shipped
- AE86 rear view mirror cover - $10 shipped
- AE86 clutch release bearing fork - $40 shipped
- AE86 clutch release hub and bearing - $50 shipped
- AE86 clutch release bearing - $25 shipped
- AE86 exhaust flanges - $10 each shipped
- AE86 OEM front lower control arms - $110 shipped
AE86 SR-5
- AE86 SR-5 steering wheel - $40 shipped
- AE86 SR-5 wheels - $60 (requires shipping quote)
- AE86 SR-5 wheel cover - $15 shipped
7A-FE
- 7AFE water pump - $40 shipped
MA46
MA46 Celica Supra rear end parts:
- MA46 OEM 4-link trailing arms - $100 shipped
- MA46 E-brake cable - $30 shipped
- MA46 7.5" Open Differential 3.73 - $175 shipped
- MA46 sway bar w/ end links - $80 shipped
- MA46 whiteline rear springs w/ insulators - $100 shipped
- MA46 14mm trailing arm bolts. Missing one nut and washer - $25 shipped
85' AE86 F20 Turbo
85' AE86 BT20V
86' AE86 BT20V
07' FJ
16' Mini CM JCW
souldrift86
Re: AE86 4A-GE 16v, 20v, F20c, MA46 and more parts!
Postby souldrift86 » Sat Feb 24, 2018 12:17 pm
F20c to AE86
F20c to AE86 parts:
- F20c OEM crank pulley - $90 shipped
- F20c OEM crank pulley bolt – $15 shipped
- F20c OEM PCV bolt - $6 shipped
- F20c AE86 NA air filter - $10 shipped
- F20c OEM head bolts - $50 shipped
- F20c OEM fuel rail w/ stock injectors, fuel pressure regulator, and fuel pulsation damper - $215 shipped
F20c AE86 turbo swap components:
Note: Parts below are specific to work together and if separated will require modification to fit. Willing to separate for potential buyers; however, it's best to keep it together:
- JSP crossmember spacers. Thin two-piece units (4 pieces total) – engine sits higher than standard JSP mounts. - $40...
- JSP passenger side engine mount modified to clear bottom mount turbo and exhaust to fit. - $100...
- S2000 OBX racing turbo manifold w/ threaded holes added for double-ended studs - studs with bolts and washers included (paid $50 for these). Professionally re-welded and strengthened collector. (GT3582 was previously attached to this – not included). - $325 (Manifold alone retails $600 new)...
- AE86 intercooler "JDM Sport" modified, 16-row, 2.75"(70mm) diameter. Requires modification to fit pop-up headlights. Silicone hoses and piping included. 4” piping w/ air filter, clamp, and silicone hose for turbo. Fits Levin front-end. Wastegate removed from piping. - $170...
- Turbo filter w/ piping, hose, and clamps for GT3582 - $80 shipped
- 3" downpipe, O2 sensor bung, heat wrapped, and protected with spray-on silicone. Recommend size 15 rims or larger for best ground clearance. - $190...
- 3" straight exhaust w/ v-band clamps (one clamp is slightly bent but fixable), polished angled-tip, professionally ceramic coated in 2000-degree high-temp satin black. - $350...
Misc items:
- Weldon Hi-Flow fuel pump #1100-A w/ ORB-10 to AN-10 male flare fittings and AE86 GT-S fuel pump hanger converted for external use - $400 shipped for both
- T3 rear upper links and lateral rod w/o spherical ball ends. I swapped out these links for longer units for my celica supra swap and these are leftover. Spherical ball ends are easily available separately along with spacers to make complete. - $225 shipped
- Apexi Hybrid intercooler, dual-core (two 12-row cores), 3" (80mm) diameter. Requires modification to fit AE86 - $225 (requires shipping quote)
- Elevo steering wheel - $50 shipped
- Meister Werks shift knob neo-chrome finish - $25 shipped
- EIII USA intercooler 2.25” new in box - $90 shipped
- SPAL fan shroud gasket 16" - $8 shipped
- Misc engine items are shown in final pics – make offer
85' AE86 F20 Turbo
85' AE86 BT20V
86' AE86 BT20V
07' FJ
16' Mini CM JCW
notnilc20
Postby notnilc20 » Sat Feb 24, 2018 7:22 pm
Pmed you about the fender liners
souldrift86
Postby souldrift86 » Sun Feb 25, 2018 7:41 am
Replied to message but stuck in outbox. Hit me up 530 949 723 zero
85' AE86 F20 Turbo
85' AE86 BT20V
86' AE86 BT20V
07' FJ
16' Mini CM JCW
notnilc20
Postby notnilc20 » Sun Feb 25, 2018 8:30 am
souldrift86 wrote:Replied to message but stuck in outbox. Hit me up 530 949 723 zero
Got the msg and I sent the money already with a lil extra for tge paypal fees. Thanks!
CloudStrife
Postby CloudStrife » Sun Feb 25, 2018 8:34 am
Ah bro, is that the fuel pipe from filter to fuel rail? I need that!
souldrift86
Postby souldrift86 » Sun Feb 25, 2018 11:55 am
Got it bro! Thanks. Will be sending it soon.
85' AE86 F20 Turbo
85' AE86 BT20V
86' AE86 BT20V
07' FJ
16' Mini CM JCW
sja4ag
Postby sja4ag » Sun Feb 25, 2018 2:36 pm
Need the OEM 20v clutch flywheel and pressure plate asap! please call/text me 415-806-7313 . I can paypal you today
1986 coupe, 20v blacktop -- grippy boy
1985 hatch shell, x2 20v silvertops + a lot more goodies -- $2500 (msg me if you want details)
sja4ag
Postby sja4ag » Sun Feb 25, 2018 5:32 pm
^^^I'm local as well
souldrift86
Postby souldrift86 » Tue Feb 27, 2018 5:58 pm
CloudStrife wrote:Ah bro, is that the fuel pipe from filter to fuel rail? I need that!
Hey bro, sorry it's pending sale. I'll let you know if it falls through
85' AE86 F20 Turbo
85' AE86 BT20V
86' AE86 BT20V
07' FJ
16' Mini CM JCW
souldrift86
Postby souldrift86 » Tue Feb 27, 2018 5:59 pm
sja4ag wrote:Need the OEM 20v clutch flywheel and pressure plate asap! please call/text me 415-806-7313 . I can paypal you today
I'll hit you up soon
85' AE86 F20 Turbo
85' AE86 BT20V
86' AE86 BT20V
07' FJ
16' Mini CM JCW
souldrift86
Postby souldrift86 » Tue Feb 27, 2018 6:49 pm
Thanks bro! Sent it today and provided tracking via USPS. Enjoy!
85' AE86 F20 Turbo
85' AE86 BT20V
86' AE86 BT20V
07' FJ
16' Mini CM JCW
buish
Postby buish » Wed Feb 28, 2018 4:40 am
i'm interested in the - 4A-GE 16v GT-S IACV - $55 shipped.
PM'd you
souldrift86
Postby souldrift86 » Wed Feb 28, 2018 9:27 am
buish wrote:i'm interested in the - 4A-GE 16v GT-S IACV - $55 shipped.
PM'd you
Replied to message with payment details. Thanks bro!
85' AE86 F20 Turbo
85' AE86 BT20V
86' AE86 BT20V
07' FJ
16' Mini CM JCW
buish
Postby buish » Wed Feb 28, 2018 11:35 am
payment sent. thanks.
souldrift86
Postby souldrift86 » Wed Feb 28, 2018 6:24 pm
buish wrote:payment sent. thanks.
Sent package today with tracking. Thank you!
85' AE86 F20 Turbo
85' AE86 BT20V
86' AE86 BT20V
07' FJ
16' Mini CM JCW
souldrift86
Postby souldrift86 » Wed Feb 28, 2018 6:26 pm
Spark plug cover and fuel filter w/ bracket & soft line sold.
85' AE86 F20 Turbo
85' AE86 BT20V
86' AE86 BT20V
07' FJ
16' Mini CM JCW
souldrift86
Postby souldrift86 » Thu Mar 01, 2018 7:56 pm
AFM setup and GT-S 16v TVIS w/ EGR sold
85' AE86 F20 Turbo
85' AE86 BT20V
86' AE86 BT20V
07' FJ
16' Mini CM JCW
souldrift86
Postby souldrift86 » Fri Mar 02, 2018 6:31 pm
GT-S OEM shifter sold
85' AE86 F20 Turbo
85' AE86 BT20V
86' AE86 BT20V
07' FJ
16' Mini CM JCW
Rynomann56
Postby Rynomann56 » Wed May 16, 2018 3:06 pm
Would u happen to have any engine harness for a gts 1985
souldrift86
Postby souldrift86 » Mon May 21, 2018 2:14 pm
Rynomann56 wrote:Would u happen to have any engine harness for a gts 1985
I don't, sorry. Thanks.
85' AE86 F20 Turbo
85' AE86 BT20V
86' AE86 BT20V
07' FJ
16' Mini CM JCW
Rhdhecks
Postby Rhdhecks » Sat Aug 04, 2018 9:52 pm
Do you Still have the cross member spacers?
Users browsing this forum: No registered users and 9 guests
