Socal Clean Title 1985 Gts Hatch part out!
cerumo
Postby cerumo » Wed Aug 02, 2017 10:48 am
Parting out a 1985 Corolla Gts Hatch and Selling Spare parts I've been hoarding over the years. Ask for anything I did not post, and I'll see if I have
it. I Will post more parts. Running GTS hatch parting out with low mileage on rebuild.
Text at six two six-five three six- 0066 Price is obo.
Sold 1985 Corolla Gts Hatch. It has no rust. It comes with doors, no fenders or hoods. Bring your own front suspensions and rear ends so you can
roll it out. Chassis has been hit on the driver side.
It has been repaired and replaced with new radiator support.
Sold JDM Trueno Kouki front and rear bumpers with bumper support, Local pick up only. No bumper lights.
Sold JDM Trueno Zenki lip
Sold SR5 transmission without bell housing
450 Brand New HKS Sport exhaust
350 Brand new Corolla GTS Oem Catback exhaust
800 Brand New Apexi Hybrid Megaphone exhaust
Sold 1985 GTS Hatch under dash harness
250 1985 GTS Hatch engine bay harness
200 1985 GTS Rear Hatch harness
Sold OEM gts header and downpipe
Sold OEM down pipe with after market cat
350 Like New Fortune Auto 500 rears adjustable shocks. Drove for 50 miles and took them off.
250 Megan rear adjustable shocks
Sold Rebuild hi-comp long block with .5 oversized stock pistons,new oil pump, blue top cams, bronze guilds, upgraded springs, decked block and
head, .08 TRD head gasket. It does not come with accessory. Compression test more than 210 psi on each cylinder. Or i can separated head and the
block.
1000 Resurfaced and rebuild Low Comp 4age 16v head with brand new Tomei 268 exhaust and intake cams.
300 water line assembly
100 Red top injectors
150 250 cc injector for Oem harness with Hi comp motor
Sold TRD 4-1 header
150 T3 Pand hard Rod.
200 HKS Cams gears
2500 GTS Zenki rear differential Assembly, used for 1000 miles with all new 4.3 ring and Pinion, new bearings, new Tomei 1.5 way lsd, new Oem
brake pads, New Brake cables and Re-manufactured brake calipers and new Goodrich Braid brake lines
Sold Rebuilded GTS transmission with new Seals and Synchros rings.
350 Used Brian Crower 280 exhaust and intake cams
350 500 miles resurfaced light weight oem black top 20v flywheels and exedy clutch.
Sold Red Gts Hood
300 Completed 1986 Corolla Sr5 front bumpers assembly with Grill.
150 Headlights assembly
150 Gts cluster.
100 Good working Gts Heater Core
200 GTS rear seat
120 Front seat belts
100 Rear seat belts
150 GTS rebuild distributor
150 GTS Intake manifold assembly
150 Gts K&N intake
150 Good working mass air flow meter with intake tube
150 Igniter with new MSD Blaster 2
80 brake booster
Sold Front and rear carpets
250 AE86 cracked dash
450 Rebuild manual rack with new inner and outer tie rods
150 manual u joint and shaft
Sold Ae86 Steering column with key
300 Gts hatch rear wing
150 TRD Engine mounts
100 Speedo cable
Sold New Aisin cluch slave and new TRD clutch line
100 GTS clutch hardline
80 Aisin clutch master
40 Gts clutch pedal
40 Gts Brake pedal
40 Gts Gas Pedal
sja4ag
Re: Socal 85 Gts Hatch part out!
Postby sja4ag » Thu Aug 03, 2017 3:03 pm
heater core? didnt see it listed but thought id ask
1986 coupe, 20v blacktop -- grippy boy
1985 hatch shell, x2 20v silvertops + a lot more goodies -- $2500 (msg me if you want details)
basilss
Postby basilss » Mon Aug 07, 2017 10:52 pm
AC Idle up VSV available?
Road 2 roku
Postby Road 2 roku » Wed Aug 09, 2017 1:02 pm
Contacted you about a cluster, still waiting on reply.
Road 2 roku
Postby Road 2 roku » Sat Aug 12, 2017 6:57 pm
I have tried contacting you, but rarely receive replies.
cerumo
Re: Socal Clean Title 1985 Gts Hatch part out!
Postby cerumo » Thu Oct 25, 2018 1:51 am
Back for more....
Jafet
Postby Jafet » Tue Nov 06, 2018 9:47 pm
By any chance do you have lower control arms?
Ita Racer
Postby Ita Racer » Tue Nov 13, 2018 5:49 pm
I would care to buy the gear box. Can you tell more about the condition. The rebuild. How much for shipping. Please reply
85 AE86 Race Car
91 Supra non turbo
96 Celica convertible
2006 4 Runner
cerumo
Postby cerumo » Wed Jan 09, 2019 6:50 pm
Updated sold parts!
jungle168
Postby jungle168 » Sat Feb 02, 2019 8:46 pm
Would you happen to have any interior pieces?
Dusk. Until the Sky Crashes. Est.1998
cerumo
Postby cerumo » Tue Apr 23, 2019 11:45 am
Only have kick panels
St. Bushy
Postby St. Bushy » Sat May 04, 2019 4:34 pm
Looking for the headlight relay retractor with female plug located behind driver headlight, do you have it by chance?
Rhdhecks
Postby Rhdhecks » Fri May 24, 2019 1:11 am
Still have speedo cable?email me Oneeviljdmef9@sbcglobal.net
