Even if i put a wire to the thing on the steering wheel to a ground it does not go off. why?
davew7 wrote:Use a test lamp and see if you have current going into the horn. If you do not see current at the horn check the fuse. If you do not see current, in either of these cases, you have a problem with a plug connection or a broken wire. Odds are pretty low that the horn actually stopped working. Dave W
davew7 wrote:A test lamp is just a 12V lite with two wires or clips that you can attach any wire to verify that you have current at the the test point. You could actally make one by soliding two wires to a lite bulb. Or buy one at a auto parts. They look like a screw driver with a point on the end and an alligator clip to attach to your hot lead wire. Dave W
