"New" 4AGE: high comp, w/OST-032 ported head
Postby oldeskewltoy » Sat Jan 23, 2016 8:06 am
As title states... I have a completely re-manufactured high comp 4AGE with OST-032 ported head... and it comes with its own delivery device - a 1987 FX16!!
I bought this last spring when I believed my wife and I were moving from Portland to Eugene, so I would have a "commuter" going from Eugene to Portland. Those plans fell flat, we stayed in Portland, so I have no need for this special FX16.
This is a genuine FX16... just not an FX16 GTS... so this is far more stealthy
When I bought the FX it had a bad engine... cyl 3 had ingested a spark plug electrode and did significant damage to both the head and the block. So a new engine was built........
Now to the "New" engine:
7 rib none squirter block, 40mm rod journal crank, 40/18 rods modified to take a press fit 20mm wrist pin, 81.5mm aftermarket 10.3 to one pistons, new Toyota rod bolts/nuts, short block assembled by Loynings, Cometic .036 head gasket, stock 87 and earlier cams, new Toyota (OST ported) oil pump, AEM adjustable timing pulleys, and an OST ported largeport head with a Loynings valve job... All Toyota gaskets except Cometic .036" head gasket
link to head build - http://club4ag.com/forums/viewtopic.php?f=7&t=15894
edit - car/engine in Portland, Oregon
$3500 or best offer...
Re: "New" 4AGE: high comp, w/OST-032 ported head
Postby oldeskewltoy » Mon Feb 15, 2016 12:58 pm
bump this beast
casket77
Postby casket77 » Wed Mar 02, 2016 6:47 pm
PM Sent...
Garage7RP
Postby Garage7RP » Thu Mar 03, 2016 9:33 am
Will it pass CA smog?
Postby oldeskewltoy » Fri Mar 04, 2016 1:21 pm
got PM... responded...
Will it pass Ca smog.... there is no reason why it shouldn't.... but the reg/emissions are still good in Oregon till October... so I haven't checked.
Grunt my AE95 sedan popped another head gasket so I've been using this for a bit.... it pulls well from 2500, all the way to redline.... The car itself has a few flaws.... clock and fuel gauge inop, rear hatch, or tail lamps leak, a few squeaks and rattles, but she drives straight, and brakes straight.
Postby oldeskewltoy » Wed Mar 23, 2016 12:32 pm
I should raise the price..........
4th gear pull... - 120.5 whp 109#/ft........ and look at that low end :shock:
I even have video - :D
Postby Deuce Cam » Wed Mar 23, 2016 1:31 pm
This thing is so legit. I'm really surprised it hasn't sold yet.
Postby oldeskewltoy » Wed Mar 30, 2016 9:19 am
http://ost.ebeans.ch/albums/userpics/10001/Skippy_dyno_120hp.mp4 - horsepower on left dial, torque on right :mrgreen:
oldae82
Postby oldae82 » Mon Apr 11, 2016 6:17 pm
Can you give me some pics on the body and interior? A/C and etc. working? Manual trans?
oldae82
Postby oldeskewltoy » Tue May 03, 2016 4:39 pm
oldae82 wrote:Can you give me some pics on the body and interior? A/C and etc. working? Manual trans?
apologies didn't see your request....
no A/C. Manual trans... does grind on occasion going into 3rd gear
as to pics... these taken today....
InitialB
Postby InitialB » Tue May 03, 2016 9:17 pm
My god OST... This thing is in really good shape. GLWS. Wish I had 3k and a plane ticket up there.
Postby oldeskewltoy » Tue May 31, 2016 7:34 am
bump... still available... still pulls like OX ;)
Postby oldeskewltoy » Fri Oct 21, 2016 2:51 pm
I DON'T want to re-register and re-insure... email me offers........... oldeskewltoy@yahoo.com
Rogue-AE95
Postby Rogue-AE95 » Fri Oct 21, 2016 6:54 pm
If I didn't live on the other side of the country, and already have a 3rd car to use for my daily driver...
taroroot
Postby taroroot » Sun Oct 23, 2016 1:58 pm
Dang, I just dropped almost that much to rebuild just the 20V in mine, and my body's quickly rusting now!
I actually prefer the FX16 to the GTS for the stuff I do, auto and rally-X. Good luck!
Postby oldeskewltoy » Fri Jan 27, 2017 9:11 am
bump.........
MtLemmon86
Postby MtLemmon86 » Thu Mar 23, 2017 11:16 pm
Private message sent.
Postby oldeskewltoy » Fri Mar 24, 2017 3:24 pm
MtLemmon86 wrote:Private message sent.
replied......
shipping this any other way then using the shell to "get it to you"... isn't likely to happen.
From a shippers standpoint this is a used engine carrying "harmful" chemicals (oil and coolant), as such most shippers will not take the engine on its own.
"get it to you" - the car can be driven, it has some flaws... but the car is road capable. The only other way I know is to ship the whole car... as in using a car transporter.
