I'm selling a custom turbo piping setup for an AE92. Will come with piping, couplers, and Mishimoto intercooler. There is a fitting that will need to be blocked off if not used. It was suppose to be for the Megasquirt PNP sensor needed to run a MAP setup. To fit, you will need to cut a portion of metal on either side of the radiator. $350
I also have a 2.5 inch downpipe with flex pipe and a v-band setup; the length goes about 3/4 down the exhaust tunnel - $150
Megasquirt PNP (MS DIYPNP V1.5) (unbuilt) will bring hardware to build, plugs to connect to your laptop, sensor for motor to eliminate AFM;- SOLD!
4age ebay turbo manifold - SOLD!
Small T3 Rebuilt Turbo - SOLD!
7MGTE Injectors (All 6) - SOLD!
Tial Wastegate with 7 PSI spring (Installed, never used) - SOLD!
Powdercoated 4age Valve Covers with breather holes and AN fittings - $125
Authentic SARD FPR (Installed for placement, never used) with -6 AN fittings - SOLD!
20 Valve tranny plate to block the front starter hole and open the starter hole in the rear - $40
https://www.dropbox.com/sh/apghi1xvjnop ... 2x-Ka?dl=0
Faster responses through email - t_byron239 at yahoo dot com
FS: Turbo Setup Part Out for AE92 & 4age Related Parts
truenorican
Re: FS: Turbo Setup Part Out for AE92 & 4age Related Parts
Email sent regarding valve covers.
Email sent for injectors please, they are the direct fit 440cc ?
truenorican
Wastegate and Injectors SOLD!
truenorican
A bunch of parts sold! Updated list!
