Group A specifications
Postby oldeskewltoy » Fri May 15, 2015 8:03 am
Often times when researching performance engines we here of Group A, or N2. These specifications, at least Group A, are based on the specifications allowed by the F.I.A. in the AE86 homologation paperwork. The AE86 homologation papers for the AE86 are; A-5179 (for the coupe), and A-5180(for the hatchback)
from the A-5180 papers.... 3 door/hatchback - here are most of the specifications listed....
1599cc max
minimum rod mass - 431 grams - length 122mm - big end diameter 43mm (so no 42mm cranks!)
minimum crank mass - 11540 grams
flywheel cast iron minimum mass - 7060 grams
55mm T/B
injectors in head (not in intake)
maximum valve lift - 7.2mm - clearances .2mm, and .25mm
number of intake manifold elements - 2 (TVIS plate and intake??)
exhaust cast iron
max intake valve diameter 30.7mm, 6mm stem
max exhaust valve diameter 25.7mm, 6mm stem
wet sump oil system
As I read it... that leaves a LOT of room for special machining, and head porting. It also has cam lift listed... but not durations.... no mention of compression ratios either.... no mention of adjustable cam pulleys either....
so if you are looking to build a Group A engine.... you begin with the proper specification :mrgreen:
turboae92
Re: Group A specifications
Postby turboae92 » Fri May 15, 2015 8:10 pm
This is very interesting.Oldeskewtoy do you have 4age bible??
Postby oldeskewltoy » Sat May 16, 2015 8:56 am
turboae92 wrote:This is very interesting.Oldeskewtoy do you have 4age bible??
yes I do... the TRD pistons listed in the Bible were the basis for my piston design
turboae92
Postby turboae92 » Sat May 16, 2015 12:13 pm
Can you share some of specifications on the parts that made n2 race cars, engine parts like camshaft lift, duration, compression, camshaft size, rotating assembly weight.
Postby oldeskewltoy » Sat May 16, 2015 12:24 pm
turboae92 wrote:Can you share some of specifications on the parts that made n2 race cars, engine parts like camshaft lift, duration, compression, camshaft size, rotating assembly weight.
many... think of a milder 9500rpm Formula Atlantic engine... O/S valve, 11.5 to 1 cr, 270 to 300+ duration - 10mm lift cams
turboae92
Postby turboae92 » Mon May 18, 2015 3:27 pm
Thanks, about how much power they were making at the time??
Postby oldeskewltoy » Mon May 18, 2015 3:52 pm
turboae92 wrote:Thanks, about how much power they were making at the time??
205-210 hp @ about 9000-9500.
turboae92
Postby turboae92 » Mon May 18, 2015 7:50 pm
Those are good numbers.Thanks buddy..
